Anyone converted oil heater to use waste oil, is it possible?
Bob G
01-06-2003 08:02:59
I just bought a used oil heater for my shop to replace my wood heater. The recommendation is to use #1, but is it possible to use waster oil? I really just curious, but if it is possible I may experiment with it.
Thanks,
Earl S.
01-07-2003 12:44:59
 Re: Anyone converted oil heater to use waste oil, is it possible? in reply to Bob G, 01-06-2003 08:02:59
Bob, First I want you to know I am not trying to sell a furnace. I just want to pass on some info. SAE 40,SAE10-40, Waste oil,ATF, #2 fuel oil are what can be used in most all brands of waste oil furnace.They can all be dumped in the same tank.I know for a fact that they love ATF & hyd oil they burn clean. They don't like antifreeze or water.So if people give you oil make sure it is clean. Do a search on waste oil furnace there are several on the market. The less expensive just don't have all the whistle & bells and require more attention to get a good clean burn.Have fun FREE HEAT!!! Earl S.
Elton Fancher
01-07-2003 04:11:34
My brother-in-law has a large auto salvage business and burns motor oil in a forced air system (designed and sold specifically for that purpose) in his dismantling shop. I do know that they initially had some problem with condensation but overcame that. It is also legal with the EPA to do this.
paul
01-06-2003 20:21:27
I was wondering about that too. I don't generate 100's of gallons of used oil to get a waste heater, & don't want the liability issues of collecting that much these days.
But, some diesel engines (before cat converters) allowed one to mix in some clean used engine oil with the fuel.
Could one add a gallon of used oil to 10 or 25 gal of heating fuel & make it work?
--->Paul
T_Bone
01-07-2003 07:39:37
 Re: Re: Anyone converted oil heater to use waste oil, is it possible? in reply to paul, 01-06-2003 20:21:27
Hi paul,
I found that if you take the waste oil and premix it with a couple gallons of fuel oil then add it to the tank, you have less problems. Some oils will take alot of time to combine with #2 if not premixed.
T_Bone
Captain.n/e,Mo.
01-06-2003 16:21:00
check out the link
Captain.n/e,Mo.
01-06-2003 16:22:46
 Re: Re: Anyone converted oil heater to use waste oil, is it possible? in reply to Captain.n/e,Mo., 01-06-2003 16:21:00
didn't work ,here it is Link
Brian
01-06-2003 14:30:19
Search the web for TCD Enterprises they make a conversion kit for old fuel oil furnaces to waste oil. If you e-mail me I will send you the link
Earl S.
01-06-2003 09:36:22
I sell REZNOR waste oil furnace. 3 things the oil is pre heated and we have a on board air compressor, the other furnace co. use shop air. The nozzle flow is computer controlled for different oil viscosities. They have come a long way from the old drip type.
