Concrete pump
carl
01-05-2003 18:14:19
I had a chance to buy a trailer mounted concrete pump,minus the V-4 wisconsin and hose.I don't want to put another wisconsin on it;any suggestions? What is a cheap type of hose I could use and dispose. We are going to pour a lot of concrete and this could be a Godsend.very open to suggestions
Steve-IL
01-06-2003 16:04:45
 Re: concrete pump in reply to carl , 01-05-2003 18:14:19
I've been around a lot of concrete pumps in the road building world. Be careful spending too much on it without a guarantee that it WILL PUMP concrete once you add a fresh engine. The engine will be the cheap part. If the pump needs reconditioning that will cost $$$$. They are a great tool when they work properly.
Ray
01-06-2003 03:14:28
Carl
Dont skimp on the hose!! Those machines are a little dangerous....the hydraulic pressure of concrete is too high to risk your life to save money...Get the right stuff, as far as the motor goes I would think that any low RPM unit with the same HP rating would be sufficient. Is it an auger type or a ram machine?
