Removing Duct Tape
Bob
01-05-2003 15:19:37
I recently taped up an engine block with duct tape and now need to clean it.I have scraped as much of it as I can. What works best to remove the remains? Thanks. Bob
Bernie
01-08-2003 17:47:23
 Re: Removing Duct Tape in reply to Bob, 01-05-2003 15:19:37
Brakleen by CRC will take off glue, etc. Or similar stuff with "perc" in it. It isn't flamable but heating (welding,etc.) will produce phosgene gas, very bad to breathe.
M guy
01-07-2003 18:57:57
PVC cleaner (primer).
roy
01-06-2003 16:27:33
I use gule be gone
john d
01-06-2003 13:33:20
GUMOUT in a spray can.
rhouston
01-06-2003 10:12:13
lighter fluid is what I've used.
Jerry
01-06-2003 06:35:42
Another thing that removes adhesive labels / tape and such is wd40. You may have to have to let it soak a bit.
T_Bone
01-05-2003 22:22:47
Acetone or alcohol
T_Bone
Glenn(WV)
01-05-2003 17:04:45
There is a product called Goo-Gone. It will take off tape adhesive, the dealer badges on your car, all kinds of sticky stuff. Might give that a try.
Mac
01-05-2003 17:04:32
Try some paint thinner. Then Gunk Carb spray cleaner. I have used both and they seem to work pretty good. Still got to wipe off the slime tho. Ugh!!!
M R
01-05-2003 16:43:28
Rubbing alcohol worked for me, but I think it depends on the brand of duct tape.
