Timing light
KeninArk
01-03-2003 10:35:17
I'm looking for a timing light that can be used on a 6 volt positive ground tractor. Anybody have an idea where I might buy one?
john d
01-04-2003 09:40:03
 Re: Timing light in reply to KeninArk, 01-03-2003 10:35:17
Don't know if they are still available, but I've got an old Sears timing light that plugs into 120 volts. No connection needed to the vehicle battery, therefore it doesn't care about polarity.
willie
01-03-2003 18:59:34
Ken
need 12 volts for your timing light?? quick & dirty-get a 6 volt flashlight(lantern style) batt, a clip lead, hook in series. No cost if you happen to have one ot these flashlights in the shop, about 4 bucks if you have to buy a batt.
buck
01-03-2003 15:30:52
I agree with the other post about connecting to a 12V power source however,Snap On for one has lights that have their own power source built in. I would suspect that auto parts stores or maby even sears may have these. I have a very old craftsman that I am sure that I have used on 6V but I can't find any literature on it.
Dennis Benson
01-03-2003 16:03:23
 Re: Re: Timing light in reply to buck, 01-03-2003 15:30:52
Try sears.com, and click on parts, you will be able to get parts breakdowns by typing in the model number, and you might be able to get the manual for it.
Richard Fazio
01-03-2003 12:29:49
I don't know if you have a 12 volt one, but what I do is connect the powered unit up to a 12 volt battery and put the sensor on the 6 volt systems ignition wire. Works fine. sometimes I pull a handy vehicle with a 12 volt system next to my tractor. I've never seen a 6 volt timing light. You could probably use the old type that is not powered and gets it's power right from the ignition wire only. They are not very bright though.
KeninArk
01-06-2003 07:57:57
 Re: Re: Timing light in reply to Richard Fazio, 01-03-2003 12:29:49
Thanks to all of you for the information - several good ideas here.
mj
01-03-2003 15:15:54
What 'Richard Fazio' said.
T_Bone
01-03-2003 17:12:28
 Re: Re: Re: Timing light in reply to mj, 01-03-2003 15:15:54
Hi Kenin,
You can also use a tach for timing engines.
Run the engine at 1500rpm, not a critical rpm as all you need to do is get the carb working on the main jet and off the idle jet.
Advance the distributor until the engine begins to miss. Retard the timing until the miss stops then retard another 40rpm. Your done!
This type of timing accounts for all worn parts in the system. Once you get good at this method you don't need a tach. I've been using this method for the past 30yrs and it works very well.
T_Bone
Farmered
01-04-2003 04:52:42
 Re: Re: Re: Re: Timing light in reply to T_Bone, 01-03-2003 17:12:28
T_Bone, Your method also automatically corrects for such variables as altitide. This probably would not be a factor in Arkansas but is for sure here in Colorado at 5600 feet. Ed
