Utilty Trailer
Dave F.
01-02-2003 22:29:01
I am looking to purchase an 6x16ft. Dual axle trailer with the angle iron side rails, Its made by Hartsog, Trailer co. Wilkesboro, NC. and is rated as an 5000GVWR and 3500 GAWR My intended purpose is to haul an Farmall cub tractor and my tow vehicle is an 95 Ford F-150 I already have an weight dist. hitch Is this enought trailer to haul an cub tractor? also Is Hartsog an good trailer? Thanks Dave F.
Tom
01-03-2003 18:21:02
 Re: Utilty Trailer in reply to Dave F., 01-02-2003 22:29:01
I would suggest that you get a trailer that has a large enough deck to fit a full size vehicle on it, a pickup. Sooner or later someone will bread down and call you to come and get them, you will want to transport a car somewhere, or something else like this and a 6 foot wide trailer is close but no go. You will have spent almost all the money to get a little larger one, and be wishing it was larger I think. Don't get one with the pipe rails either, limits what you can put on it, you can always put side boards on if you need to. At mosthave a maybe 2" lip around the front and sides, but no rails.
A cub wieghs 1700 lbs, and anything you put on , wheel weights, implements etc, can bring the weight up to 2500 without too much trouble.
Dennis Benson
01-03-2003 07:33:07
That trailer sounds like pleanty to haul a Farmall Cub. The weight ratings seem a little low, it might be worth sliding down under some of the trailers and measuring the steel, and comparing axles and springs and tires for their rating. I would want to make sure it is a quality that will last. I bought a 5 by 8 utility trailer that looked big enough when I bought it, but then I started using it regularly to haul loads of scrap metal. Most of the loads were half it's capacity, but soon the trailer was catwalking down the highway. I checked it out and found the tongue was bent. The tongue was made from about 1/16 rectangular tubing. I ground off all the welds and replaced it with the same outside dimensions, but with 1/4 think steel tubing. As for size, like the others said, it will always seem to be getting smaller and smaller. When you have the trailer you will be finding more uses for it, and you may be wishing you bought it a little bigger, or a little heavier.
krum
01-03-2003 05:14:39
Someone commented on only having a 6 foot wide trailer. I see two advantages about this. It keeps the weight down and you can see around the trailer/load better when traveling down the road. If you live in a state like Wisconsin and your trailer and load is under 3000# you do need trailer license or trailer brakes (not aways good to be without the brakes). A trailer like this is increasingly in demand as they are being used to transport ATV's and golf carts, so if you ever decide you want a bigger trailer, the 6x16 has a good resale. Just my thoughts-krum
Dan
01-03-2003 04:50:05
I have a 6x12 tandam axel trailer with 3500lb axels and electric brakes I can pull my cub with a 5 foot woods mower behind my 95 half ton chevy six cyl. no problems at all
old fart
01-03-2003 03:07:23
I would be hesitant to buy a six foot for the reason that it will not be as easy to resell as a full size car trailer. With your truck you could pull a full size and not give up any ride or economy. Just my preference,good luck.Also you would have room to haul a extra when you decide to add on.
Charles(Mo)
01-03-2003 04:29:46
 Re: Re: Utilty Trailer in reply to old fart, 01-03-2003 03:07:23
I thought that the 6' trailer was the full size. When I was looking to buy a utility trailer, I found that 5' and 6' were the standard widths for utility trailers. A couple of places that I checked had a 6 1/2' utility. Car hauler trailers that I have seen, usually don't have side rails.
Charles
BB
01-03-2003 05:02:53
 Re: Re: Re: Utilty Trailer in reply to Charles(Mo), 01-03-2003 04:29:46
Trailers that are slightly over 6' are desireable for anyone who might have 6' wide implements. My tractor with 6' rotary cutter needs a trailer that is at least 6'-4" wide.
old fart
01-03-2003 02:39:22
Slowpoke
01-03-2003 01:48:03
If two axles are rated at 3500GAWR each, then the GVWR should be 7000lbs, plenty to haul a standard Cub. The Cub will get lost on a 16' deck as it's only about 9' long. With a weight distributing hitch, you won't even know it's there. The Cub weighs about 1450lbs. I don't know anything about the brand of trailer you want.
