New style grease zerk or what?
Jerry A.
01-01-2003 16:54:10
I was just rotating the tires on my 2002 Chrysler minivan and noticed a funny styled grease zerk on the lower ball joint on the front suspenion. It had no "groove" (or narrowed area) to snap on a grease gun...it was just smooth on the sides and shorter than a standard zerk. I replaced it with a "normal" zerk and shot some grease into the joint/rubber boot cover.
Is this something new or have I been out of touch with the automotive industry for a few years? Is there a different type of grease gun fitting that works on such a zerk?
Thanks
Mac
01-01-2003 18:05:17
 Re: New style grease zerk or what? in reply to Jerry A., 01-01-2003 16:54:10
I believe this is a button head fitting. Another deal so DIY'rs have a hassle, and dealers would have to grease. There is an adapter.
You are lucky as a lot of new cars have NO fittings at all. They used to use plugs that had to be removed each time you greased. Had to use a pointed rubber adapter. Plugs could be removed and fittings installed however. Careful and do not overgrease since you have regular fittings installed.
