Tools
Professional Or
12-31-2002 14:12:43
I am in the process of reorganizing my tools - I am curious - How do you guys organize your tool box? What tool do you keep in the top and what goes in the bottom or are you into something different? Irv
SteveB(wi)
01-03-2003 10:34:41
 Re: Tools in reply to Professional Organization, 12-31-2002 14:12:43
Heavy low to prevent tip over
Nolan
01-02-2003 03:36:14
Top down:
1
Screwdrivers, standard in left, phillips in right.
Allen wrenches in back of phillips, pouched.
2
standard
Combination wrenches in left, sockets in right. Wrenches trayed, sockets on racks.
3
metric
4
Pliers and such in left,
ratches, breakers, extensions in right.
5
Odd specialty tools
(note, 5 is being placed in cardboard bin storage with other items currently. 4 is to be broken up between 4 and 5.
6
files, saws and other cutting/shaping instruments.
7
hammers in right, drifts, punches and chisels in left.
8
Extra sockets, wrenches and such.
JD790
01-01-2003 13:03:09
third party image
Here is a good example of how not to do it! She was really loaded for road work too!
I have seen guys build a frame that a top box can sit in and a lifting Bracket can be hooked on top and in front to lift and move them. When it is locked down it is pretty hard to pry any drawers open.
Some day I am going to Rig mine for easier and safer transporting. But not really fond of road work anymore.???
david
12-31-2002 21:46:41
Lots of good ideas. Main thing is find a system that works for you in what you do and where you do it.
For me I need to move with a complete set of tools, in my pickup, with me all the time. We farm over 4 counties 60 miles to far points with other "mechanical" interests as far as 150 miles. As the "chief cook and bottle washer" I can't run back and get stuff. I carry 2 small boxes in my pickup. 1 is a Craftsman $99.00 socket set (1/4. 3/8.1/2 drive) through 1-1/4. Ratchets and wrenches are pulled.
Those wrenches are in the top tray of box 2, a grey Craftsman "hanyman". Also 3/8 and 1/4 ratchet and 5 screw drives, allen wrenches, and feeler gauges. Bottem of box has a full set of combinaton wrenches 1/4 to 1-1/4, plus 2 1/2 ratchets and a set of drifts and punches. Keep both boxes on drivers side next to cab. Leave space between them and keep a 3 hammers (claw, ball pein, black smiths) 2 pipe wrenches, channel locks (4 sets 8-30"), and a set of cheater bars.
Keep a set of 30 and 50 caliber ammo cans at the shop with common parts and wrenches for each piece of equip plus a can for plumbing, fencing, and electrical. Grab what ever cans for the jobs I'm going to or send them with a guy going out so he can handle minor repairs. It's not complete but it is very portable. Keep boxes at the shop with big wrench and socket sets.
Must be nice to keep up with tools.
Bill C.
12-31-2002 20:32:45
Great question, lots of great answers.
Since I'm on the road a lot, I get to work with many mechanics and see how they set up their tools, and they are all different. I've set up a "road box" with the most common and needed tools, and it goes where I go. Actually it's two boxes. When I'm home, they sit on top of one of my roll cabs, either at the shop or at home. The road box has changed quite a bit over the last 30 years, and will probably do a little adjusting in the next 30...
Just keep the most used tools ready to hand, and always put them back! Nothing worse than hunting for an hour to do a 5 minute job.
Like Skinner said, you're not done till they're cleaned and accounted for. Important for me, working on turbines OR tractors!
BFO
12-31-2002 17:34:58
I have 2 each, top cab and roll cab combinations. One top gets 1/2" drive sockets and accesseries, the other top gets 3/8 and1/4. All wrenches and metric tools are in the left combo, along with power tools, pullers, screw drivers, etc. The right combo gets specialty tools, drill bits, slings, air tools..... .... HTH
john
12-31-2002 17:17:00
Irv,
My main tool storage is a craftsman roll around with two intermediate boxes and a top box..with a side box hanging on... about 26 drawers total.. the heavy stuff air tools, impact sockets etc go in the bottom two drawers... next up is cresents and large combo/open end drawer (1" to 2") next up is metric wrenches then up to standard wrenches. We're about hip high now.. next is plier drawer, then screw drivers. next four drawers are divided between 3/4, 1/2 and 3/8 sockets/acces. with holders for standard and metric, 6pt, 12 pt and 8 pt. the higher you go the less used tools... crowfoot, universal sockets, precision tools (mics,calipers) then top drawers are for seldom used smaller stuff. The side cabinet is vicegrips top drawer and down thru tube benders, flare tools, metal punches and chisels, nut-sert and poprivet tools and special tools for brakes, etc..
There is a 10 drawer workbench under my metal workbench (cut down to fit) with large hammers, files, squares, large calipers, two misc junk/tool drawers..etc Another set of drawers (under another bench) contain soldering guns/irons, staplers, plumbing tools and all this is under another work bench.. one drawer for sandpaper/disc,belts. two drawers for manuals and paper work and one empty drawer for hiding stuff.. :-)
I need more drawers and more tools !!!
Keep your most used stuff below eye level and above bending over level within easy reach of the bench or car or whatever you're working on.. a roll around cart helps a lot. A bucket boss is great for transporting and I keep a full set of everything in mine ready to pick up and go...
john
Wayne
12-31-2002 23:22:18
 Re: Re: Tools in reply to john, 12-31-2002 17:17:00
Dad and I work on heavy equipment for a living, everything from the old Northwest and BE cranes down to the smaller farm tractors that our neighbors have. We are currently running 2 service trucks,a C-6500 with a 11'bed and 8000# crane, and a FL-106 Freightliner with a 17'bed and a 11,000# crane, and both are loaded down with tools. On top of all that, add a shop with a lathe, mill, drill press, welder, etc, etc, also full of tools. Thing is we have the same problem as the rest of you guys....THERE ARE NEVER ENOUGH TOOLS or enough space.... In keeping with the question asked though, we usually keep sockets, etc in the top of the box, and work down from there, using the long drawers, with the rachets, pliers, metric wrenches, standard wrenches up to 11/16, standard wrenches 3/4 up, then screwdrivers, special tools, pry bars and long punches, hammers, small air tools, then in the bottom the 3/4 drive impact and sockets for it. The remainder of the small/narrow drawers get used for allen wrenches,short punches and chisels, odd balls like torx drivers, starting screwdrivers, etc. anything left after that is fair game for test leads, tape, and the 1000 other must haves around the shop. In the end though it all comes down to the drawer arrangement of your box, how much you have to put in it, and personal prefference.
Skinner
12-31-2002 16:54:49
I use the top of the chest for my sockets. I cut some plywood the size I wanted, put a lip around the bottom, and screwed my socket rails to it. It has a handle in the middle so I just grab it and go. Sounds cheezy but it's routed and stained and looks like it belongs to a cabinet (ok, may be pushing it a little).
The first one was made of steel but it weighed too much. Never was happy with the premade ones, since most were plastic or too shallow. I just wanted it to be quick and easy and since sockets and ratchets were the most commonly used is the reason I elected to do it the way I did. I have 3 full size roll arounds in my shop( 2 snap ons & 1 Mac) and They are very well organized. I can tell when I'm missing a socket or wrench or just about anything. The job is never finished until the tools a cleaned and accounted for. Especially since my tools cost more than that Silverado I may have been working on.
Dennis Benson
12-31-2002 16:46:22
I have several work areas, one in the process ov being moved.
My truck has a service body, and I keep tools handy for dismantling scrap metal and machines fast.
I use 5 gallon buckets for organizing tools for work out side on the ground for repairing.
I have a mechanic shop that I'm planning to move from the basement to a 24 by 24 barn in the back yard. I have 2 roller cabinets, and I'm planning a third so that I can organize the metric and American tools separately to make it easier to pick up the right tool, and make room to improve my 3/4 sockets and add 1 inch sockets. I arrange tools by size and by how much I use them, keeping them easy to access. I'm planning to add a valve grinder to the top of the third tool cabinet. I like a drawer on each machine for the tools I use around that machine only.
I'm building up a collection of woodworking tools that I haven't decided on yet for making and repairing furniture. I'm collecting some antique tools so I can make authentic repairs for the period furniture.
Al
12-31-2002 16:13:18
Just a thought? Are you thinking in terms of a mechanic , carpenter, handy man etc... I'm a Bldg Contractor and keep a lot of tools in my truck.
Irv
01-01-2003 07:51:14
 Re: Re: Tools in reply to Al, 12-31-2002 16:13:18
I had in mind my mechanical tools and my carpentry stuff. I am reorganizing my stuff and wanted to hear what other have done. Never can have too many ideas. Thanx, Irv
