McCulloch gas/oil ratio
rossow (mn)
04-17-2000 05:16:08
I picked up a slightly used 12-inch McCulloch "Mac 110" chain saw at a yard sale Saturday. It has no owner's manual, and the owner's wife knew nothing about it. Does anyone know, or know where I could find, the correct gas/oil ratio? It's not listed on the saw. My McCulloch weed whip and McCulloch 20-inch chain saw both call for 40:1, but I want to be sure before I use that mix in the smaller saw. Thanks in advance for any help.
needs manual
01-31-2005 22:50:27
 Re: McCulloch gas/oil ratio in reply to rossow (mn), 04-17-2000 05:16:08
My son purchased a used McCulloch 16" Mac 110 2.0 C.I.D. chain saw. The model # is: 60001603 and the serial # is: 18-163701.
I am looking for an owner's manual for this saw. Does anyone have one that can be photocopied or know where I can get one?
Please email me at: [email protected]
Thanks.
lucas wheeler
12-13-2002 16:15:53
just run it at 40:1 rato. if the saw runs hard at that rato mix it at a 32:1 rato.
same saw
03-26-2001 13:07:34
I own the same saw and the manual calls for 20:1 ratio for other oils and 40:1 for the mcCulloch oil. I myself have been using a 40:1 ratio with all oils. Hope that helps you.
Jason
07-27-2002 01:10:58
 Re: Re: McCulloch gas/oil ratio in reply to same saw, 03-26-2001 13:07:34
I have been searching the web to find out how many oz of oil to mix in a one gallon of gas at 40:1 No one seem to know this one not even my girl friend who is cooledge educated she has no idea how many oz in a gallon or a quart ...Can some one please help!!!!! !!!!! !!!!! !!!!! !1
bart
08-17-2002 08:26:28
 Re: Re: Re: McCulloch gas/oil ratio in reply to Jason , 07-27-2002 01:10:58
Link
try this the table should help you
newer ones=40 to 1.....
04-17-2000 17:02:31
older ones use 32to 1,I've used both and have had no problems.
Paul D. Melliff
03-22-2001 11:24:59
 Re: Re: McCulloch gas/oil ratio in reply to newer ones=40 to 1....., 04-17-2000 17:02:31
I'm looking for replacement parts for a
McCulloch Gas Weed Earter. I'm pretty sure they have gone out of business. But I decided to try anyway. I'm not even sure if I'm using this the right way, or not? If somebody can help me, please send me an e-mail to the email address above. The # is: SMH032UB24Ra, Non-Working # is:
1-800-423-6302, 17" Cut, Name is: Power Pro.
It is a 32CC, Another #: C094. If this is not the right place to ask this kind of question, maybe somebody will know something, and can put me in that direction. Thank you very much. Have a wonderful day. Take care.
Sincerely, Mr. Paul D. Melliff
Lynn Busby
04-18-2000 05:55:44
Most of my McCulloch chain saws specify 40:1 and my weed eaters specify 32:1. So you say it's ok to use a 40:1 ratio for both? I would rather just mix one batch of either. thanks.
Tool Man
04-18-2000 12:35:20
 Re: Re: Re: McCulloch gas/oil ratio in reply to Lynn Busby, 04-18-2000 05:55:44
Just use 32:1. Gas/oi9l ratios aren't as critical as most people think. If you wanted to be extra safe, do 20:1. I would use 32:1 myself. As a bonus, you only need to mix one batch of gas.
Old Henry
05-29-2000 07:14:17
 Re: Re: Re: Re: McCulloch gas/oil ratio in reply to Tool Man, 04-18-2000 12:35:20
We used to cut wood a lot of wood. Had a Jonsered
SP49, Mac 1010, several Echo saws, & Stihl.
Ran them all at 20:1. Jonsered was by far the best saw I ever seen. This was an older model w/ metal housing & parts... no plastic. The old Mac did fine as long as you didn't shut it off. Hardest thing to start after it got hot.
