AC Generator Service Help???
JohnG
12-26-2002 17:59:45
I have a Homelite 4000 Watt generator that's only charging on 120 volts instead of 220. Only one leg is producing current. Any ideas on what to look for and does any one know where to get repair manual for a Homelite generator. I checked with manufactuer and they do not have a manual. Thanks for your help.
Bob M
12-28-2002 06:22:40
 Re: AC Generator Service Help??? in reply to JohnG, 12-26-2002 17:59:45
John - Pull off the end bell, then check the wiring between the stator winding and the output receptacle(s) for a break on the dead side. Also check the circuit breaker on the dead side for continuity.
The above are OK, then check the dead side stator winding for continuity. If you find no continutity, best bet is take the generator head to a electric motor shop for repair. Good luck!
