Parts washer fluid?
Chris MF35
12-25-2002 07:57:04
got a 20 gal parts washer from wife today. what kind of fluid works best without breaking the bank on cost?
Jim M (RI)
12-26-2002 06:51:18
 Re: parts washer fluid? in reply to Chris MF35, 12-25-2002 07:57:04
I used a product made by Castrol that is available in Walmart. It is relatively inexpensive, enviornmentally safe, and cleans well. I dilute it about 3/1. Not very good on your hands so I use rubber gloves. Happy Holidays! Jim
Jerry A.
12-26-2002 05:14:04
I've used the soil based fluids (Soy Gold) in parts cleaner. Not cheap to buy. I'm not that impressed with the degreasing qualities of the stuff. Mineral spirits work better for getting grease off parts. The Soy Gold has a low odor and leaves an oily coating on the parts (not necessarily bad).
When this soy fluid is fully contaminated, I think I'll buy the low odor mineral spirits.
Farmer/Paul
12-25-2002 18:56:06
I just run varsol in mine. When it gets dirty enough ( it took 4 years for the 1st batch), it goes to a friend who runs it through on of those used oil furnaces.
David - OR
12-25-2002 10:19:52
Not to disparage wives or goods from the Far East, but I learned the hard way that the plastic used in the pumps in those cheap Chinese parts washers gets dissolved in mineral spirits.
If she bought it at Harbor Freight, or through some non-brick-and-mortar Internet supplier, be careful what you put through it.
You will have little more than a 20 gallon rectangular soaking tank if you try to use strong petroleum solvents like paint thinner with the cheap pumps.
Frank M.
12-25-2002 16:07:57
 Re: Re: parts washer fluid? in reply to David - OR, 12-25-2002 10:19:52
I bought my parts washer at one of the side-of-the-road traveling tool peddlers. It's made in China. I put mineral spirits in it. It's almost a year old now, and the pump still works fine. Only problem is the switch. It self-destructed after about a month. I bypassed it, so I have to pull the plug to shut it off.
BTW the 20 gallons will fill it to the top. I bought 14 gallons of mineral spirits and it was over the top of the shelf.
bob
12-25-2002 09:51:44
Chriss is right about water souble cleaner. check price and if it fits use it if not use what you have too but be carefull disposing it as there is some problems with some chemicals. I don,t have a parts washer but at work we had to be real carefull bob
john niolon
12-25-2002 08:39:43
The very best I've found is a product called "Super Agitene" it sold by WW Grainger for one.. it is a petroleum based product but is very user friendly.. Nice to your hands and no bad smell that stays with you for days..
It's a little expensive.. around 50 bucks for 5 gallons.. I have a small cleaner and 5 gallons was just enough.. but I'd have to think about buying 20 gallons... that gets into my truck project money a little too much... :-)
john
Mike C.
12-25-2002 08:16:32
I use mineral spirit in mine works O.K. and a whole lot cheaper than the other stuff.
Chris
12-25-2002 08:16:10
The politically correct answer is to use water based concentrate available from most parts houses. Actually it works good and IS enviromentally safer than Kerosine or Diesel fuel.( Nudge,Nudge,Wink,Wink)
Skinner
12-25-2002 13:15:10
 Re: Re: parts washer fluid? in reply to Chris, 12-25-2002 08:16:10
I use Varsol in mine without any problems and it's a el cheapo model. Here, 5 gallons of Varsol is $19.95.
bob
12-26-2002 17:32:45
 Re: Re: Re: parts washer fluid? in reply to Skinner, 12-25-2002 13:15:10
if you want a really cheap and good cleaning fluid, go to your friendly dry cleaners and get their used dry cleaning fluid. works great, doesnt smell bad, usually a freeby, water soluable, what more do you want.
Chris
12-26-2002 20:03:33
 Re: Re: Re: Re: parts washer fluid? in reply to bob, 12-26-2002 17:32:45
And it is Carcenogenic to boot! The contact hazzard is mostly skin contact and vapor inhilation of the fluid! Perchlorethyline (Perc) is NOT somthing you want to use to wash parts! DO NOT!
Glenn(WV)
12-29-2002 20:10:22
 Re: Re: Re: Re: Re: parts washer fluid? in reply to Chris, 12-26-2002 20:03:33
Agree with that. There is a building here in town that used to house a dry cleaning co. In the days before the EPA regulated that stuff, the dry cleaner would just dump it into a drain and down in the ground it went. It polluted a large part of our water supply, so much so that three municipal water wells had to be shut off. The EPA is supposed to be cleaning up sometime in the near future; with the way they do things, it won't happen for 200 years. lol
