smoking Brigs motor
Mike c.
12-24-2002 10:44:46
I have an 11 hp. Brigs and straton motor that smokes realy bad under load. Its also spitting oil out the carb. This thing doesnt have that maney hours on it. Can anyone tell me wats the matter with it?
Thank you. Mike C.
Richard
12-25-2002 00:42:58
 Re: smoking Brigs motor in reply to Mike c., 12-24-2002 10:44:46
Don't know about the larger Briggs engines, but I had one of the older cast-iron types that smoked like crazy, it was on a garden tiller and I called it my tiller and fumigator. Anyway, the problem turned out to be that someone had removed the tin baffel inside the valve chamber that is located under the little plate behind the carb. If you look in there, there should be a little "u" shaped pressed steel baffel along with the valve stems. Sure changed my old engine around when I put one in there. The mosquitos liked it better too.
Ben in KY
12-26-2002 05:38:53
 Re: Re: smoking Brigs motor in reply to Richard, 12-25-2002 00:42:58
Good point Richard, That would definately cause the problem. Did not think of that.
Wayne Swenson
12-24-2002 21:18:35
Check the crankcase breather; the fiber disc should not move in & out more than .030" to .040".
Someone may have stuck a finger in it one time and now it cannot close & produce a vacuum in the crankcase.
I found many of these while teaching Vocational Small Engine mechanics for 30+ years.
Ben in KY
12-24-2002 17:36:34
If it does not have too much oil in it. It could be bad. Too much blowby will force the oil out thru the breather into the carb. Many of these non commercial grade Briggs can be blown in a very short time if they are run while low on oil. If it lookd like blowby is the cause, you might try re-ringing it. Probably wont get it back to new running, but might keep it running for quite a while.
TimC
12-24-2002 12:25:06
Too much oil in the crank case might cause some to get into the pcv valve that is connected to the carb on some motors.
kruse
12-24-2002 12:34:55
 Re: Re: smoking Brigs motor in reply to TimC, 12-24-2002 12:25:06
Also, check to make sure the air cleaner/air passage isn't blocked (air cleaner is now probably full of oil too).
