Question on sharpening a chain saw blade
Dan Robinson
12-16-2002 19:33:05
I am looking for a product that would help automate sharpening a chain saw - the teeth. Is there a product that will maintain the proper angle of the tool used to sharpen the teeth, while advancing the chain a link at a time? I am looking for a powered grinding product.
Jim
01-05-2003 15:35:53
 Re: Question on sharpening a chain saw blade in reply to Dan Robinson, 12-16-2002 19:33:05
I have one of the file guides also. With the correct file and clamping the bar in my vise I can sharpen a chain as well as the machine. Also I do agree it is the best to use the file and guide at least every other tank, or as soon as you hit the dirt or a rock.
RJ WI
12-17-2002 10:18:42
Stihl makes a great chain sharpener. It's a little spendy, but it does all the different angles and depth's w/o too much trouble. Don't forget, you need to know chain size, tooth angle, rake depth, etc. to do a good job. A poorly sharpened chain is a costly mistake.
M.R.
12-17-2002 09:40:00
Check this production one out. Do not know know if it takes a wheel barrel or a boat load of dollars to own. ;>]
gene from mich
12-17-2002 09:14:55
makwe sure u have the proper size file for your chain your local dealer ship or hardware store should have what u need. you can free hand file a few times and them get it done on the machine and also the raker teethat the same time .. if your saw begins to cut in a half circle you wioll know its time to take it to the shop. also check the bar for square or flat on the chain grove
Ben in KY
12-17-2002 10:28:26
 Re: Re: Question on sharpening a chain saw blade in reply to gene from mich, 12-17-2002 09:14:55
I have always used the 3.95 oregon chain saw sharpener file and jig. Just watch your angle and take the same amount of strokes on each tooth. I found that it takes me about the same amount of time to do it this way as using a power sharpener. Also if my angle is off a bit I do less dmaage with the manual method than the powered one. It just takes me about 15 minutes to sharpen it this way, just about right for a break anyway.
John
12-17-2002 09:06:34
When I get a new chain, I make sure I get the correct file right away. Then I give it a quick filing after every tank or two shile using the machine. The key is to give each side the same number of passes with the file. Make sure you are using the same angles that were there when you bought the chain. I like using a vise to hold the bar and then on the push stroke, even when the tooth moves to the side, I maintain the correct angles.
mj
12-17-2002 07:07:08
Get yourself a file and then cut enough wood to learn how to use it. Oh yeah, keep the chain out of the dirt if you're limbing or bucking up firewood.
Vern-MI
12-17-2002 06:35:05
Some chains are difficult to sharpen while on the bar especially if the chain and bar are worn. The chain rocks from side to side while the pressure of sharpening is applied. So then the angle must be controlled in both planes while the chain is rocking back and forth. Every now and then they should be removed and sharpened on a machine which will hold the chain securely.
Bus Driver
12-17-2002 05:44:40
Readily available, but not cheap. Some units may cost $450.00.
Paul (QC)
12-17-2002 03:41:31
I bought the following and it is fantastic. I'd never
sharpened a chain in my life and I get great results.
Easy to use and fast.
Click on the link below then click on :
-> FILES, GRINDERS: files - chain grinders - accessories
-> Chain grinders
-> Professional chain grinder Item #45500
They have more expensive grinders but this one is fine.
Oregon also markets a similar grinder but the motor was not reversible (like the one above) last time I checked.
kraig WY
12-16-2002 20:32:21
Most hardware stores carry the guide you're looking for. Personally I rather sharpen them by hand, same with drill bits. Seems to be quicker and I get better results.
