Propane shop heater
Chris Smith
12-15-2002 09:31:12
I have a propane shop heater. It is a coleman powermate heater. It is a one burner with ignitor and thermocouple. It won't lite. I have tried a match and the electric thing.. Guy that gave it to me said it was working and just quit. So what should I be looking for? Any help welcome..
later, Chris Smith
Bill
12-16-2002 15:48:43
 Re: propane shop heater in reply to Chris Smith, 12-15-2002 09:31:12
Propane heaters are nice. But before I invested any money in one I'd consider propane, at least here in the northeast is about 30 cents more per gallon than #1 fuel oil/kereo & the BTU content is 91,500 btu per gallon for propane versus 136,000 btu per gallon for the kero. Propane is just a little better than electric heat cost wise..... If I were to buy a shop heater I'd go kero/much more BTU fer the buck.
evielboweviel
12-16-2002 15:34:30
check for spider nest or web in the orfice and/or tubes
Mac
12-16-2002 11:06:18
Best bet would be get Mod No. amd E-mail coleman.
Maybe look at their web site and see if there is one like the one you have. Maybe get a parts/operators manual also.
Chris Smith
12-16-2002 10:50:51
I am pretty sure the burner is bad. it rattles and refuses to light. So any one kow where to get one for a coleman powermate? Or is there an after marktet one i can get? All help is appreciated..
Later, Chris Sm
Chris smith
12-15-2002 10:34:55
I don't believe this one has a pilot light. It is the style that mounts on the side of a 20 lb tank. There is just a burner and the gas goes from a nozzle on the valve and is directed into the burner by a metal tube. It just doesn't want to light.. I haver never had one of these before so if you could explain how to light it, i might be doing it wrong.
Chris Smith
12-15-2002 09:39:58
The thermocouple works. heat it up and it the button, it stays on..
JoeK
12-15-2002 10:14:41
 Re: Re: propane shop heater in reply to Chris Smith, 12-15-2002 09:39:58
This is normal
Turn on gas supply,set to pilot
Start button ignites pilot with spark-
Pilot warms thermocouple-
Thermocouple opens main gas valve when warm-
Gas flows to main burner and is ignited by pilot.
At what point does yours fail?What type/size of fuel tank are you using?Model No of heater.
