Hand Held RPM gauge
rem
12-15-2002 04:58:35
Wanted:
Hand held RPM gauge to measure speeds on AC All Crop Harvestor
Dennis Benson
12-18-2002 19:01:01
 Re: Hand Held RPM gauge in reply to rem, 12-15-2002 04:58:35
I have a handheld plastic tachometer. It is in a plastic pouch with Thechumseh on it. It was made in West Germany, and everything on it is in German. My wife only knows some of the words she heard her mother, grandmother and great grandmother, and a lot were swear words anyway. The tachometer works by placing it against the engine or case, and turning a knob which extends a wire, when the wire stops vibrating you remove the tachometer and read the guage. You shpould be able to buy ine from a lawn mower shop that sells Techumseh parts.
mj
12-18-2002 14:01:17
If you want get get creative a speedometer, any speedometer (unless it's marked otherwise on the face), is calibrated to 1000 revs per mile SO you could.....well, you get the picture, right?
Nathan(GA)
12-15-2002 19:39:23
Harbor Freight had one in a catalog a few months ago for about $39, I think???? You never know about that stuff. Some of it's good, some junk.
Gene Davis
12-15-2002 17:07:30
I have a round hand held Stewart Warner that my father bought back in the early 50's, except for replacing the rubber tip on the business end of the spindle a couple of times, it has had nothing done to it. About once or twice a year it needs a drop of light oil to lubricate the spindle shaft. I always put it back in it's case when finished using it, but check 1000's of combine vylinders, tractor p.t.o, shaft speeds etc. while he was with JD. and I use it occasionaly now, it is very accurate and very easy to use, think places like Grainger and McMaster-Carr sell them. I highly reccomend it, wew checked all combine cylinder sspeeds wirh it when setting up combines for JD 11A's 12A's 25's 30's and an occasional IH or AC combine and never had a problem with this unit.
Chris
12-15-2002 11:20:52
McMaster-Carr should still have them.
JoeK
12-15-2002 10:20:20
Engine speeds?Cheapest would prolly be Dwell/Tach used in past for setting points on cars/trucks.tractors.Seldom used anymore with electronic ignitions on almost everything.Lots of em in pawn shops etc,not expensive new...2 wires,one to dist side of coil,one to ground.Make sure used one has right cylinder settings for you,ie:4cyl,6cyl,8cyl.
JMS/MN
12-15-2002 09:24:57
Check with suppliers to machine shops, tractor dealers, etc. Lufkin is one brand.
