In easy steps. #1. Get a 2 stroke that calls for 20:1 mixture. Note: This proceedure was tested using a 1972 Ski-Doo Olympique 335 others will be similar.#2. Test Amsoil synthetic 2 stroke oil. Use a 60:1 mixture, only mix one gallon. #3 Run out of gas. Preferably miles from home, and/or anyplace you could convieniently mix up some of that nice Amsoil. #4 Refill with 50:1 mix of conventional oil. #5 Decide that the conventional at 50:1 is just as good as the Amsoil. #6 Go for a good hard run. Preferably ending up miles from home. Always ride with a buddy, but make sure his sled is too small/light to comfortably tow yours, it'd help if his isn't running particularly well either, maybe it should die when it idles. #7 If you notice the engine making funny noises, be sure to ignore them. Pass if off as belt slap or clutch noise. Oh yes ladies and gentlemen, I've ruined a 2 stroke top end. Coincidentally now I know what a 2 stroke without enough lubrication sounds like. It goes "ting, ta ting ting" like the sound a loose belt slapping a snowsled clutch makes. Or if you had a screw or something in the exhaust... Still the Amsoil was good stuff, and I'll try it again once I break in the new top end.
