Grass Trimmer
Tobit
04-15-2000 04:21:23
Hello,
I have the weedeater featherlite grasss trimmer and was wondering if anyone could give me the instructions on how to set the caburettor and limiter caps and how to set the throllte trigger. I assume it is basically the same for nearlly all petrol grass trimmers so even if u don't have the exact one anyhelp would be appreciated.
Thankyou
James Ha
05-11-2001 00:30:45
 Re: Grass Trimmer in reply to Tobit, 04-15-2000 04:21:23
An attachment to straight-shaft brush cutter for safe & easy operation,saving cost and effectiveness with great manicured cut.
Cynthia Cameron
05-03-2001 11:16:34
I have just aquired a featherlite weedeater XT 200. I need to get a manual so that I can run an care for it. Do you have any ideas?
Faye Graham
04-27-2002 06:03:40
 Re: Re: Grass Trimmer in reply to Cynthia Cameron, 05-03-2001 11:16:34
My Mom has a featherlite (don't know what the serial # or such is) and she has lost the manual, she can't figure out how to replace the string. Can you help her? You may e-mail me back the information, at the e-mail address I have given.
Bob
04-15-2000 18:49:04
This has worked for me on trimmers - also chain saws, etc:
1 - Identify the carb 3 adjusting screws: First is the idle speed adjustment - a mechanical stop contacting the throttle lever. Second is the low speed mixture adjustment. Often it's marked "L". (If not marked, it's the mixture screw NEAREST the engine on the carb.) Last is the high speed mixture adjustment. It usually marked "H". (If not marked it'll be the mixture screw NEAREST the air filter. Note - not all engines have an "H" adjustment - many newer ones have a fixed high speed orifice and are non-adjustable).
2 - Make sure you have FRESH gas and a clean air filter. Begin by starting the engine and letting it warm up a couple minutes. Make sure the choke is full open.
3 - Adjust the "L" screw 1/8 turn at a time until you find the spot the where the motor runs fastest.
4 - Now adjust the idle speed screw until you get your desired idle speed.
5 - Go back and re-adjust the "L" screw again for the smoothest idle.
If you have no "H" screw, you are finished. If not...
6 - Quickly pull the throttle to full speed. If the motor stumbles or dies, it's too lean - open the "H" adjustment 1/8 turn at a time until the motor picks up immediately. If the motor picks up OK but smokes and runs rough at full speed it's too rich - close the "H" screw 1/8 turn at a time until the motor runs smoothly at full throttle.
7 - Finally, when you get the "H" set where you want it, go back once more and readjust the "L" screw for the best idle.
Hope this helps!
Bob
PS - If the carb is completely out of adjusment, begin by turning the "L" and "H" screws LIGHTLY all the way in (do not force!). Then give each screw about 1-1/2 turns open. This will usually be right to get a motor started at least.
Mike Beck
05-26-2005 22:28:22
 Re: Re: Grass Trimmer in reply to Bob, 04-15-2000 18:49:04
Great Old School advice, Bob!
thomas lambert
09-05-2000 17:14:13
what if you tune the h and l needles 1/2 way between the
the lean and rich studder? take care T lambert
thomas lambert
09-07-2000 16:14:35
 Re: Re: Re: Grass Trimmer in reply to thomas lambert, 09-05-2000 17:14:13
