Hi Eric, As a weld cools it shrinks a very small amount at a faster rate than the surrounding base metal. By peening the weld your stretching the weld face slightly so it more closely matchs the base metal contraction. Normally with a good joint design, peening is not required. So what is a good joint design? This can discussed at length so I'll only cover the basics with a couple examples. Thin gauge metal when butt welded has to have the correct root opening. If both pieces are butted together tight, tacked then welded, the joint will heave in the center of the weld as it's cooling creating a small "V" shape in the base metal. Now you could peen this bead and get the metal to lay flat but in doing so it will create stress pockets out of the weld zone thus creating a bubble in the base metal. Why? Your expanding two different thickness, the base metal and the weld bead. The weld bead being thicker will add force on the base metal thus creating the bubble. All metal thickness requires this root opening not just lite gauge. Take that same butt joint design with a root opening 1/2 of the base metal thickness, tack at 25 times the base metal thickness for between tack centers, then weld, and now it will lay flat after it's been welded. Why? The root opening allows for the weld puddle to draw the two base metal pieces together and just touch as the weld cools. This joint would not require any peening. Keeping with this thought, why peen a weld on castiron? Here we have two different metals joining together. The castiron having a very open grain structure where as the weld metal has a tighter grain structure so they pull against one another just like the thin gauge metal did. Here if we lightly peen the weld bead as the castiron cools will allow for the expansion of the weld bead to closer match that contracting rate of the castiron thus resulting in a weld with less stress. By covering the compeleted welded joint and letting it cool slowly also helps relieve the stress. If not peened or heat treated then theres a greater chance for the weld to crack away from the base metal.
T_Bone
