MIG vs Oxy-Acet vs TIG?
Bryan H
12-10-2002 14:33:39
I do not know too much about mig welding. Although I can kick butt at oxy-acet, welding with 15% silfos used for copper in HVAC/R. Therefor the oxy-acet method really intrigues me. I am doing a 1927 T-Bucket frame off, and want to fab the floor board, firewall, gas tank, and interior panels out of plain aluminum diamond plate. (thickness' unknown at this time) Would the oxy-acet method work for me and if so what would I need to do this? Or if another way would be better, what kind of stuff should I be looking at to purchase, to do the job correctly? I am very willing to learn so all feedback will be very usefull to me. Thank you guys for all your help.
P.S. Or should I just suck it up and purchase a TIG welder? Keep in mind, there is an enourmous amount of welding to be done
Scooter
12-13-2002 17:54:05
 Re: MIG vs Oxy-Acet vs TIG? in reply to Bryan H, 12-10-2002 14:33:39
Purchased a lincoln squarewave welder and this works great to do body repaires restoring a 62 ss Impala
T_Bone
12-10-2002 18:45:59
Hi Bryan,
Tig is very nice as it has a very controled arc thus would have a slightly tighter heat zone area. If you weld more than 1/8" then you will need a wet Tig torch and need a 250amp AC HF( high frequency) machine in any AL welding. A T-17 dry torch will handle slightly less than 150amps but it gets awful warm. Is Tig cost effective for home use? Not for me!
You can Oxy/Acet weld AL without any problems. Most
AL doesn't require a flux if your torch is adjust correct, neutral flame and the base metal is kept clean.
The key to welding AL is keeping it clean. As you weld AL, your weld puddle will become contamiated with black oxides, don't matter which process you choose. Stop and clean with a new SS wire brush, one that has not been used on any other metal and on a drill motor works best. Clean until you hit white metal. If you don't pull the filler rod out of the gas zone then you will keep contamination to a minmium, on all processes.
When asking welding questions always include the material thickness as this helps to give advice on your projects.
T_Bone
