Space heater question
dave s.
12-08-2002 12:54:34
I have a space heater that will not refire after I unplug it.Anybody know what the problem could be? If I take the hood off and tinker with it usually will fire,but this is a pain .
hazfun7
12-09-2002 16:06:10
 Re: space heater question in reply to dave s., 12-08-2002 12:54:34
Hi,Your nozzle is dirty.(By spark plug)3/4
socket.Pull it out soak it in carburator cleaner.I use a tourch cleaner after I soak
it. Good Luck Keno
dave s.
12-09-2002 15:53:48
The heater I have problems with is a Torpedo type that runs off of #1 kero. The brand is ACE of Ace Industrial Products Division of Century Engineering Corp. 97,000 BTU Mod.# 100ES I know I never herd of them before.
mike werner
12-09-2002 17:22:18
 Re: Re: space heater question in reply to dave s., 12-09-2002 15:53:48
These heaters can be a royal pain,but I repair them for a hardware store.
Start at the fuel supply screen inside the fuel supply tube-(this connects with a flare nut on the nozzle housing).
Make sure this is clean.
Next,check nozzle,spark plug,and fire-eye.
Clean ttese also.
Then check air filter,and air pressure.
To check pressure,most pumps have a plastic plug in the housing.Then,take a low pressure gauge,and a hose barb fitting and hose, and screw fitting into hole for plastic plug.
Then locate the fitting with a screwdriver slot and steel ball in it. This is the pressure regulator. Screw in for more pressure,out for less.
The key is aprox. 2 p.s.i. MAX.
When done, the center of the burner chamber should be red in the center.
Hope this helps you!
Mike
dave s.
12-10-2002 13:18:22
 Re: Re: Re: space heater question in reply to mike werner, 12-09-2002 17:22:18
Thanks for the info Mike, it should help alot. Do you know if parts are available for this brand or do most parts interchange w/ other brands? I tryed to locate the company but no luck.
mike werner
12-12-2002 12:01:55
 Re: Re: Re: Re: space heater question in reply to dave s., 12-10-2002 13:18:22
Hi Dave-
MOST parts are interchangeable.
There Is only a few manufacturers of these,Desa being the most common.
DAVE .S
12-12-2002 15:51:15
 Re: Re: Re: Re: Re: space heater question in reply to mike werner, 12-12-2002 12:01:55
Thanks Mike, I ripped the unit down yesterday and cleaned and checked everything. It turned out to be the sentrifigal finns on the pump, they were all gumed up. Works good now! Thanks for the info
paul
12-09-2002 10:45:45
Kero, diesel, propane?
Convection, blower, infared?
Push ignite, electric, sparker?
And so on, too many options for anyone to make an intellegent reply.
--->Paul
Bryan H
12-08-2002 16:57:34
I am a HVAC Tech/Installer. What kind of space heater is it? gas or electric? portable (small like for under a desk for your feet) or like a regular heater for your house? who makes it? do you have a model number? More info is needed to answer you question.
