Electrical Problem
Update
Crank
12-07-2002 11:34:53
You guys were exaclty right. The splice that I had put in the nuetral wire had oxidized. It was my own fault, I didn't use a splice fitting approved for aluminum wire or use an anti-oxidant lube. Hopefully I fixed it right this time. You live and learn. Can't thank you guys enough for your input! On a side note, ground is froze about 8-10 inches here in southern MN. It was a bearcat breaking through. Dug up two toads at about 12 inches below ground. Think this means winter won't get much worse or we will have an early spring? Ground is still black here, no snow yet.
