Hi Al, Good, the round shape will help alot with distorion. Since Tig is available that would be my first choice. You'll need to use 75AR 25HE, 75HE 25AR or any of the tri-mix gasses. You can use thin strips of your scrap 316 drop off as a filler metal. I would tack weld with 309 if you want to use stick. For tacking just make them small. The 309 rod is good for dissimular metals, SS to black, etc. Since your going to finish with Tig, I would braze tack it with Oxy/Act, as it will be cleaner. Use a small neutral flame again using scrap 316 as a filler rod. If you want to try something new then I would finish weld by brazing. You will be amazed at the weld puddle control you have and is very close to Tig welding if you get the low heat set correct. The heat zone can be just as small as Tig if you have the correct tip size and flame temperature. Tip, most people tend to use to hot of flame with brazing. It should take about the same amount of heat and time to molten puddle as Tig would. T_Bone
