WHICH BRAND???
bandit
12-04-2002 15:14:52
hi i was wondering which brand of tools to buy. i had to many of the cheap harbor freight tools break on me, and im in the market for some tools. should i get Snap-On? or Mac? or what other kind??? Thanks!!
LumbrJakMan
12-05-2002 15:44:24
 Re: WHICH BRAND??? in reply to bandit, 12-04-2002 15:14:52
Home Depot will replace any Craftsman tools with there Husky Line . They are so confident there tols are superior . I am happy to say I think they are too. Good tools and not gonna need a mortgage to buy them ( Snap-On ). Theres a reason why the Snap-On guy will let you make payments each week .Think about it . Home Depot has the " Forever " Guarntee . Easy to get them back to them if they break also .
Slowpoke
12-05-2002 00:26:23
Where is the auction that gets $1 for a pallet of tools? Just previewed auction lots today; one box about 5x5x5 feet was 3/4 full of broken chain saws, drills, power saws , etc. I wouldn't be surprised to see it go for $150+, here in SFO area.
I bought one of the Harbor Freight metal band saws and made some 'improvements' to it, like an extended table. I can cut pieces as long as they are big enough to be held in a drill press vice, clamped to the table. Or I can use 'c' clamps directly to the table. I recently drilled & tapped multiple 5/16 holes in it so that bolts and assorted 'washers'can be used to clamp pieces that can't be held in the vice. Just about any angle can be cut in duplicate pieces, by clamping angle stock to the table extention. The original vice can't hold stuff less than about 5" long and parallel sides. And the angle adjustment is a pain to get back to square. So far I've had no trouble with the motor or gear box. When I got it, the first thing I did was to tilt the machine so the box is level and fill with oil made for worm gears. If there is any sign of leaks, make a new gasket and tighten it good. Those bronze gears don't like to run dry.
The next project is to refine the crude blade adjustment so it cuts straight through the stock. But it sure beats a hacksaw . John
Dennis Benson
12-05-2002 11:12:53
 Re: Re: WHICH BRAND??? in reply to Slowpoke, 12-05-2002 00:26:23
That pallet of tools for $1.00 was in Battle Creek, Michigan. People just didn't seem to be bidding that day. I also got 7 hose reels, some set up for air, and some for grease, and some for oil for 2.50 each, they weighed about 70 pounds each. I also bought a pallet of trollies that go on a 3 inch I beam for about $5.00 from that auction, they need some sandblasting, and a couple of bearings and soft plugs, I'm going to be making some overhead gantrys in my shop after I get it done. At another auction I bought a steel workbench for $5.00, it weighs a few hunded pounds and is made entirely from steel 3/16 inch thick, whenever I stopped with that bench on the way home people wanted to buy it, I'm going to be rebuilding engines on it.
I just try to get near the auctioneer in my wheelchair near a lot of things that look like they should be cheap, and when no one is bidding I try anywhere from a dollar to five dollars, and I don't care if I buy junk because I process and sell junk for extra money. I've also been known to be setting off a long distance, not paying attention and hear something being offered for a dollar and make a lot of noise and wave my arms around to get the auctioneer's attention.
Oh yes, some auctioneers have tried to sell me. "How much for the man in the wheelchair?"
earlschieb
12-04-2002 20:32:27
I have had good luck with the Evercraft line of NAPA tools, they have a great warraunty, and are fairly reasonable in price.
Ben in KY
12-04-2002 18:52:30
I have found Popular Mechanics brand sold at Wal Mart to be good tools. I like their ratchets better than craftsman. They cost more than harbor freight, but less than craftsman and a lot less than Snap-on. I have had good luck with the harbor freight sockets if I buy the 6 point impact rated sockets. Hope this helps.
Ludwig
12-05-2002 15:30:39
 Re: Re: WHICH BRAND??? in reply to Ben in KY, 12-04-2002 18:52:30
I have a bunch of Popular Mechanics wrenches that I got for small money at walmart because they were some people didn't want. One set is all larger than 3/4" (GREAT!) one is metric, one is all very small. I think I paid $20 for all three sets, maybe 30 wrenches in all. They're very durable, even the 13mm I cut off to make a snowmobile carb wrench.
Dennis Benson
12-04-2002 16:44:36
I would get a good name brand that is easy to buy in your area, and has replacements readily available. I like Craftsman wrenches and hand tools with the lifetime guarantee. The power tools only have about a year, and a lot of the craftsman power tools I've had have only lasted a few years. Snap On or Mac are good for the specialty hand tools. I do agree with Harbor freight, but found a trick, I bought a metal band saw, and used it a lot before the warranty expired, and the motor burned out. They replaced the motor for free. I took the opertunity to give a complete lube, and found a gearbox with only a small amount of oil, and it was filled with powdered metal the gears looked good, so I cleaned it out and put in new oil. The saw is now in good shape, and I like it, but it basically had to be taken apart and lubed properly, by the way, the bearings in the motor were dry, causing it set itself on fire.
A while back I bought a pallet of tools at an auction for a dollar, two I saved were air chisels with scalers attached. One was Harbor Freight's, and the other was Ingersoll Rand. I took them both apart, and the piston in the Harbor Freight was destroyed, a replacement was just a couple dollars, and the one in the Ingersoll Rand, which I find selling new with a discount at something under $200 I think, it had a good piston, it could probably be refaced on a valve grinder if I wanted to. so I would try air tools from someplace like Ingersoll Rand. Check performance to make sure they will have enough power. Electric tools I would get contractor grade tools.
Ludwig
12-05-2002 15:28:48
 Re: Re: WHICH BRAND??? in reply to Dennis Benson, 12-04-2002 16:44:36
I didn't know how much I didn't like Craftsman power tools until I built a porch with my father-in-law. He has all new (well not so new now) crapsman. Example:Sawsall. My dad has a Ryobi, probably not the best saw, but very serviceable. The Crapsman doesn't have a variable speed trigger. Theres a dial to set the speed. The variable speed trigger is great when you want to start slow and get a good clean cut.
He also had a Skil brand skill saw that had trouble with 1/2" pine... We ended up with my elderly B&D. And my B&D cordless drill, and my Estwing hammer, and, and, and....
