Hi Steve, Lets don't try and cheat the tinman or he'll burn down your house/shop really quick. The stack thimble should be triple wall. Some codes allow for double wall thimble but the cost is like $15 extra for the triple wall and offers alot more protection. It extends down 6" below the roof of the closest roof combustible but not less than 12" long and extends up threw the roof level atleast 12". The double/triple wall stack on the roof up is required to control fires from trees brushing up against the chimeny pipe. Thats a good code requirement. From the top of the stove discharge can be single wall if code allows it. So many don't any more and reqiure double wall. Lets say you say to heII with code and as long as your running the stove theres no problem with the install cause you remember where all the mistakes are and you never exceed what could cause a fire. Now you leave and your bother wants to use your shop while your gone. Your brother just fires off the stove full bore without knowing how bad you screwed up the install, goes in the house to get a cup of coffee, comes out when your shop is a blazing with fire. Happens all the time. I know it cost some money up front but it'll cost you alot more if the shop burns down. T_Bone
