Mike, I'm putting up a building about 125 feet from my house. Here's how I did mine:Water: I have both hard and soft water at my building; soft water inside, hard outside. I drilled two holes in my basement wall (below the frost line) and ran 3/4" copper pipe through them. The pipes are cemented in place with waterproof ("hydraulic") cement and covered on the outside with roofing cement. The pipes are connected to my house plumbing via shutoff valves. The pipes running from the house to the building are 1" PVC, buried 4 feet deep. At the building I have two frostproof yard hydrants. If you're not familiar with these, ask your plumbing supply house. Two good brands are Woodford and Anyflow. Yard hydrants come in different "bury depths", with 4' being typical; a four foot bury depth hydrant is about eight feet long. The hydrant has to be set in gravel so that it can drain. The hydrant drain is threaded for 1/8" pipe, I recommend that you connect a short piece of pipe or tubing to the drain to keep gravel out. Electric: I went with 100 amp service. The building needs its own service disconnect circuit breaker at the meter. I used #2 "USE" (underground service) cable, which is approved for direct burial. To comply with code, four wires were required: two hot, one neutral, one ground. The wires are buried 2 feet deep. At both ends, I ran the cables through 1-1/4" PVC conduit to a depth of 18". At the building, the conduit is inside the building, so I didn't have to go through the wall (The service wires are buried under the wall.) I have a 100 amp breaker panel in the building. A separate ground was required at the building. I originally grounded just to my yard hydrants, but the inspector required that I add two ground rods. I also had to replace the pipe clamps at the hydrants with clamps that were approved for direct burial. It probably sounds expensive to run a separate service rather than a subpanel, but you won't regret it if you're going to use any power tools in your outbuilding.
