Welding rod help
Neal in NM
12-02-2002 15:54:31
I need help identifying some welding rods a friend of mine has just purchased. The tin has 5/32T-C1 31 on it. The rods are a dark brown (kinda a rust color) with three green dots on them. There are no numbers on the rods. TIA Neal
KENT SISLER
01-17-2003 07:38:42
 Re: Welding rod help in reply to Neal in NM, 12-02-2002 15:54:31
HAVE 40,000 LBS OF WELDING RODS CONSISTING OF 304,309L,308L,ALLOY82,AND MUCH MORE,IN SIZES FROM 1/16 THRU 5/32. ALL LINCOLN MATERIAL IN ORGINAL BOXES OR DRUMS. COMING FROM A JOB SITE THAT IS FINISHED.
WOULD YOU HAVE ANY IDEAS ON WHOM OR WHAT SUPPLY COMPANY WOULD BE INTERRESTED IN THIS MATERIAL.
REGARDS,KENT
jp
12-05-2002 07:36:45
Reddish brown flux with 3 red dots is a E6010 5P electrode. They are intended for welding around pipe joints. If they've been damp they can be revitalized in the kitchen oven.
Bud in NC
12-03-2002 17:13:47
The 3 green dots give it away - the guys I used to work with in powerplants called them "P5" rods. I don't know the official name of them, but I recognize the 3 green dots. They're good rods - as long as you don't care how ugly the weld is. We used them on stuff that was too rusty to weld with anything thing else. Good for getting enough metal to have a starting place for a 7018.
Dave Merdian
12-03-2002 18:39:23
 Re: Re: Welding rod help in reply to Bud in NC, 12-03-2002 17:13:47
P5 welding rod is 6010. I used to burn alot of it in the shipyards.Been so long ago I forget what the dot colors are anymore.I think it was made by Linclon and came metal cans.
Frank M.
12-03-2002 19:26:01
 Re: Re: Re: Welding rod help in reply to Dave Merdian, 12-03-2002 18:39:23
Might not make any difference but Lincoln 6010 says 5P on the can.
T_Bone
12-03-2002 16:51:43
Hi Neal,
Can't help much here. Been to many years since the color dot system was used. Brown flux would be iron powder probably a 7024 rod if the flux was fairly thick and 6010 if the flux is thin on some brands. I have some Lincoln 6013 with grey flux with 3 green dots.
T_Bone
kalkan
12-03-2002 15:07:31
they can eother be E6010 or E6011 or E7018. if they were in moisture they wouldent work as good.you might as well get new ones there like $3 for a pound.
