Bench Grinder...14 Chopsaw...Drill Bits
T_Bone
11-30-2002 19:29:47
Hi All,
After two years I thought I'd dig out the new power tools I bought and use them :)
The Ryobi BHG825 8", 3/4hp, 3.1amp, bench grinder is an ok machine. Turns at 3400rpm, comes with a 36 and 60grit 5/8" arbor wheels and a tool rest with a drill bit "V" cut into the right hand rest. That works very well for sharpening drill bits. The longer the bit the easier it is to sharpen. I won't be buying a drill doctor after all. HD had the grinder for $60 on sale. Once at rpm theres very little viberation and I think whats there is caused by the 36grit wheel being out of balanced. I'll take that off and put on a sanding disc as thats what I bought it for. I wish now I would have bought two of them. I really didn't think they would be that good of quality tho.
The Millwaukee 14" chop saw is evrything I expected from my Millwaukee tools, great quality. 1.5amp, 1" arbor, max 3.75"od pipe, 5x5 tube. Don't try this at home kids, as I mounted two Norton blades on the arbor at the same time to make a special 1/4" wide cut in 3/4" plate. Worked like a dream although the cut is 5/16" wide it'll work this time. It didn't even bog the motor down and that suprised me as I questioned the 1.5amp motor rating when I bought it.
T_Bone
nat
12-01-2002 08:59:00
 Re: Bench Grinder...14 Chopsaw...Drill Bits in reply to T_Bone, 11-30-2002 19:29:47
T=bone ,I watch all your replies,and think you give good advice, and I've been doing millwright work for 20years, so not a novice but don't you mean 15 amps, not 1.5 ,Nat
T_Bone
12-01-2002 09:47:49
 Re: Re: Bench Grinder...14 Chopsaw...Drill Bits in reply to nat, 12-01-2002 08:59:00
Thanks Nat, yep it's 15amp. I was off in na na land on another project with 1.5amps ...lol
T_Bone
Green_in_MI
12-01-2002 06:51:57
Were you trying to make a rabbet or a slot(all the way through) cut with your double blade cut?
T_Bone
12-01-2002 09:50:15
 Re: Re: Bench Grinder...14 Chopsaw...Drill Bits in reply to Green_in_MI, 12-01-2002 06:51:57
It was a 1-1/4" deep X 1/4" wide slot on 3/4" plate.
Ideas?
T_Bone
Scott Green
12-01-2002 04:49:39
Hi T_Bone , You will never see me buy a drill doctor. About 8-10 years ago , A very experienced tool grinder showed me the in's and out's of sharpenning drill bits. I sharpen my own drill bits on a belt grinder. I'm going to guess ,the average bit takes me about 10 seconds.
T_Bone
12-01-2002 10:00:20
 Re: Re: Bench Grinder...14 Chopsaw...Drill Bits in reply to Scott Green, 12-01-2002 04:49:39
Hi Scott,
My hands and eyes are not what they used to be so my bits were not coming out exactly in top condition. They would cut but not for very long. With a little help from the guide rest I'm back to making a sharp bit.
Why don't you write up a "how to" on sharpening drill bits. I think everyone would enjoy that :)
T_Bone
