Rights of Eminant Domain vary dependong on jurisdiction. In my county, they do not have it. The state does. Normal practice around here is for the county to pretend like they do, and hope they get away with it. Often times they do. When they run up against someone who knows the law, they get stuck because the state usually will not go to bat for them. Since the land commission has come to you about purchasing, that makes it seem likely that your deed does not have offset provisions in it for them to use. As such, they must either purchase the land or do an eminant domain claim against it. Beware of what selling the land commision a bit of your property does to your deed! Since they do not have offsets to build a road on your land, you likely have an older deed. This is a good thing! Keeps you out of flood plains, covanants, wildlife protection and such. If you proceed with the land commission request your deed will be modified. With that modification normally comes all the baggage of current regulations. This can become highly significant. Currently, on the little county road I live, I'm the sole property owner with an old deed. The others are large parcels of some farms that were broken up a decade or two ago. I'm the primary piece of land holding up a major road expansion (to the relief of my neighbors). I also don't have to play flood plain games because of my creek (all my neighbors do though, it's in their new deeds). I also can go and play in my creek to my hearts content (again, neighbors can't, as specified in their deeds). Basically, I can use my whole property for whatever strikes my fancy. Most of my neighbors can't do anything at all with most of their land. All because of their newer property deeds. So be *very* carefull about selling a portion of your land. It tends to open up a can of worms you most likely don't want opened up.
