B S 8HP MOTOR NEEDS HELP
tito
11-25-2002 04:07:35
The flywheel key has sheered three times. ran great untill i disasembled the top for a tune-up. i have double checked the gap of the points and armature. when i pull on the rope, it starts and quickly shuts off and when i check the key is broke. looking for help thanx
TITO
11-30-2002 05:29:11
 Re: B S 8HP MOTOR NEEDS HELP in reply to tito, 11-25-2002 04:07:35
thank you all for the help and responses. i was able to put the cotton-pickin' motor back in one piece and when i pulled on that dog-gone rope the little bugger started on the first pull! Much to my suprise!
i was very much suprised that i got so many response trying to help me. i was telling my friends and co-workers what a great support network you all have here. TO MY NEW FOUND FRIENDS HAPPY HOLLIDAY!
kjm
11-26-2002 19:43:18
tito, If you are trying to start a B&S it has to be a iron flywheel, or a blade or pulley on the shaft if it has an aluminum flywheel or it will shear the key.
Ichabod
11-26-2002 09:15:46
I sheared 2 keys in a B&S 16 Hp before I got the nut tight enough, or is it a bolt? I finally used a long box end wrench on the nut and turned the engine to compression, then whacked the end of the wrench real hard with a no-bounce hammer. Do that about half a dozen times and you'll have it tight enough. Did you adjust the valves? If not it might help. With too much clearance the compression release mechanism won't work.
Ichabod
Marty
11-25-2002 14:19:33
With outboard motors I have seen instructions that the flyheel nut should be torqued and it would be a good idea to use a non-hardening thread locking compound.When you inspect the nut after shearing, the key is the nut loose ?
Ben in KY
11-25-2002 12:11:05
Yes the nut has to be on tight and NO grease/oil on the tapered shaft or in the flywheel. I learned this lesson about 30 years ago.
Ben in KY
Mac
11-25-2002 10:44:13
Make sure the washer is back on right. You gotta really tighten the nut.
TimC
11-25-2002 10:33:36
You have got to get the flywheel tight when you replace it. An impact wrench might help if you lower the psi as to not over tighten.
Peter(NY)
11-25-2002 10:07:45
I believe that there is a cam lobe that opens and closes the points. If you removed this part during tune-up, make sure that it is not 180 degrees off. It's easy to put it on backwards.
