Reznor heater problem
Bill (NJ)
11-24-2002 09:06:50
I have one of those reznor model F heaters in my garage. I put an addition on my garage last year and took the heater down, at that time it was working fine. I just reinstalled the heater and now having a proplem. I light the pilot it stays lit like it's suppose to , I turn the regulator to on, pilot stays lit. When the heater fires up I can see the burners light, then the fan kicks on. After a couple minutes the heater shuts off long before it reaches the set tepmture and I notice the pilot and everyhting is off. Any ideas on what can be causing this.
Thanks,
Bill
Scott ks
11-28-2002 16:49:19
 Re: Reznor heater problem in reply to Bill (NJ), 11-24-2002 09:06:50
We got some heaters like that at work bought new. There is a thermosensor on the heatexchanger that is supposed to be touching the heat box to be a safety. The ones we got were not touching anything were just mouned in the bracket. Heater did just what you are describing.Get your flashlight and look inside where the fan blows through. It will have two wires coming off the top and the body of it is usually black. HTH
Dusty
11-24-2002 09:34:36
Air in the gas line.
Low gas pressure, too small gas line for length of line. If this is the problem pilot flame will become smaller when main burner comes on, thus not burning hot enough on thermal-couple.
Draft-wind blowing out pilot.
Dusty
