Compressor
jeff fisher
11-22-2002 09:56:53
I am mounting a York air cond. compressor on my work truck.I need to know what kind of pressure switch do I need to use on a 12v system? thanks jeff
T_Bone
11-23-2002 00:21:12
 Re: compressor in reply to jeff fisher, 11-22-2002 09:56:53
Hi Jeff,
The York piston compressors work real well for air for small portable compressors. I set one up 15yrs ago and it's still pumping strong. I use new oil thats handy, 10w30 as I have that around. There's a hex plug on the side of the case to put the oil in. I put on a paper air filter on the suction side of the pump or you could tap in the the engine air cleaner. I need to refill the crankcase about twice a year depending on how much I use it. It will pump out oil of the compressor and fill the air lines so install a oil seperator.
The compressor cycling controls for low and high pressure won't work. They brake at high pressure and close at low pressure but the low pressure is to low, 30psi. They also don't have a unloader valve and check valve.
Use a standard compressor control switch. This includes the unloader valve and some have check valves and there cheap.
T_Bone
Cliff Neubauer
11-24-2002 06:25:40
 Re: Re: compressor in reply to T_Bone, 11-23-2002 00:21:12
How much air do the York compressors put out? Will they keep up with a 1/2" drive impact wrench or even a 3/4" on a small job? We just bought a service truck and I was thinking this would be an easy cheap way to add an air compressor. The truck used to have a pto drive compressor on it so someday I might put one of those back on it or add an electric compressor when I get a welder/generator.
T_Bone
11-24-2002 11:00:21
 Re: Re: Re: compressor in reply to Cliff Neubauer, 11-24-2002 06:25:40
Hi Cliff,
The compressor by it's self would not have enough air but if you run a small storage tank along with it then you could run a 1/2" impact.
I bust 8 lug nuts loose then spin them off. I then have to wait about 5 mintues to do another wheel and I have two 5gal storage tanks. Thats at 120psi cut off. If I raised the pressure to 160psi then I probably could do two wheels then have to wait.
If I was going to use one for a "job" then I would go with something else with more CFM unless air was not needed very often.
T_Bone
Ben in KY
11-22-2002 10:14:40
Jeff, there is usually a High pressure cutoff switch and a low pressure cutoff switch. they can be part of the compressor or somewhere else in the air conditioning system.
Ben in KY
Ben in KY
11-22-2002 10:47:14
 Re: Re: compressor in reply to Ben in KY, 11-22-2002 10:14:40
Jeff, Another thought on this subject. If you are planning on using the AC compressor for compressing air. It will not last very long at all. AC compressors are designed with the idea that the freon being circulated in the ac system is carrying a special oil to lubricate the compressor, in an air compressor application the oil will not be there. Also when you first fire up the compressor it will blow quite a bit of oil out until it empties its oil sump. If you are replacing an air conditioning compressor then just check the old compressor for any pressure switches mounted in the old one and move them to the new one ( assuming they do not come on it.
Ben in KY
Richard - Only partly true
11-24-2002 06:22:48
 Re: Re: Re: compressor in reply to Ben in KY, 11-22-2002 10:47:14
This is why you must use a compressor with a sump, like the York, Tecumpsie??, or chrysler.
If the compressor is mounted vertical, then there will be very little oil consumption. I have one I used for years and years and I have it set for 200 psig. The other I used for a vacuum pump for ac systems. I put it under my drill press and turn it on and pull vacuums on my ac systems and it works great.
Ben in KY
11-24-2002 18:12:14
 Re: Re: Re: Re: compressor in reply to Richard - Only partly true, 11-24-2002 06:22:48
True about the orientation and type of the compressor. I was basing my statement on a friend/former employer's experience. He was in he Heavy equip and auto AC business. He had a Tecumsah in his truck and had to replace it about once a year. Perhaps he was running more head pressure or hours than you. He did not mind changing them out as he got them for about $40 each. I don't think he used one as a vacuum pump though, good idea, might try that one myself as my vac pump fried itself last year. Thanks for the tip.
Ben
