Military Oil Spec
Richard Fazio
11-21-2002 05:03:20
I purchased a military surplus engine. It's a twin cylinder 3HP model. The specs say to use,
Above 32 MIL-L-2104 grade 30 MIL-L-6082 grade 1065
0 to 32 MIL-L-2104 grade 10
below 0 MIL-L-46167
I'd like to be safe and know what I'm supposed to use. I'm assuming the first one MIL-L-2104 is regular 30W detergent oil. But I'd like to be sure before I try starting this thing up.
D.L.
11-21-2002 16:16:28
 Re: Military Oil Spec in reply to Richard Fazio, 11-21-2002 05:03:20
MIL-L-2104 grade 30 means as you say, a 30 weight oil. Most modern 5w-30 and 10w-30 multi-weight oils also meet this spec. The same for the other 2104 specs as well.
The "above 32", "0 to 32" and "below 0" refers to outside temperature.
MIL-L-6082 is the spec for LUBRICATING OIL, AIRCRAFT PISTON ENGINE (NON-DISPERSANT MINERAL OIL) (S/S BY SAE-J1966)
so it appears this engine can also use aircraft piston engine oil as well.
In reality, pretty much any good, modern 30w oil will be just fine in it.
Richard Fazio
11-21-2002 18:35:57
 Re: Re: Military Oil Spec in reply to D.L., 11-21-2002 16:16:28
Thanks for the info. I think the engine is made by an aircraft engine manufacturer. Thats probably why the aircraft oil spec. Thanks again. RF
