JD cam degreeing
al
04-12-2000 19:48:20
Can anyone explain the procedure for degreeing a camshaft on a JD "G"?
Al
jim
04-13-2000 23:15:09
 Re: JD cam degreeing in reply to al, 04-12-2000 19:48:20
Set #1 piston on top dead center. Now what you want to do is install camshaft gear so mark is directly inline with with center of nose on crankshaft. deere has cool tool to do this but you don't need it. Take 12" center finder head and extend out as far as possible so it looks a like a long 'Y'. Set "V' of center finder on nose of crank, rule should point directly to mark on gear. be sure to use side of rule that is center in 'v'.
