Tool steel
John S-B
11-14-2002 21:27:55
I am thinking of making a tool that would be used on concrete block,brick and concrete. What kind of steel would be suitable for this? I was thinking of something in the line of the steel that is used for the teeth on trac-hoe buckets or air chisels. Can any of you machinist guys help me? Thanks.
John S-B
11-18-2002 21:24:44
 Re: tool steel in reply to John S-B, 11-14-2002 21:27:55
Thanks for the info guys, that's a good idea about buying a tool and modifying it. What kind of steel do they use in sledge hammers?
Norm M.
11-16-2002 17:47:58
I suggest using AR-Plate or T1. T1 is commonly used on fifth wheel plates of semi-trailers
Rod MI
11-14-2002 23:05:12
I would use S-7 tool steel I works well under impact but A-2 D-2 O-1 would probable work well to what are you going to use it for
JohnS-B
11-15-2002 20:01:14
 Re: Re: tool steel in reply to Rod MI, 11-14-2002 23:05:12
It would be a hammer/sledge type tool, able to withstand heavy use.
Rod MI
11-15-2002 22:58:46
 Re: Re: Re: tool steel in reply to JohnS-B, 11-15-2002 20:01:14
I would use S-7 but its very expensive try posting this question at this link they can help you with other types of steel
T_Bone
11-17-2002 00:06:39
 Re: Re: Re: Re: tool steel in reply to Rod MI, 11-15-2002 22:58:46
Hi Rod,
Would buying a stone working tool at HomeDepot then modifiying it to fit the need be cost effective?
T_Bone
Rod MI
11-17-2002 15:25:49
 Re: Re: Re: Re: Re: tool steel in reply to T_Bone, 11-17-2002 00:06:39
That probable would work if John S-B could adapt it to what he wants it for if not use S-7. S-7 is for impact type tooling lick chisels but it�s very hard to work with like working with D-2
Rod MI
11-17-2002 15:29:03
 Re: Re: Re: Re: Re: Re: tool steel in reply to Rod MI, 11-17-2002 15:25:49
Link on S-7
T_Bone
11-17-2002 00:05:14
Hi Rod,
T_Bone
Rod MI
11-19-2002 07:43:17
 Re: Re: Re: Re: Re: tool steel in reply to T_Bone, 11-17-2002 00:05:14
That probable would work if John could adapt it to what he wants it for he must have it worked out or I think he would post back Rod MI
