An acre yds?
steve II JD4000
11-13-2002 16:32:50
can any one help me out. how many sq. foot or yds. in a acre. or size of an acre around it.
steve II JD4000
11-14-2002 11:31:00
 Re: an acre yds? in reply to steve II JD4000, 11-13-2002 16:32:50
Thanks Guys.! been looking for my book could't find it, so I give up and ask! now I could go on with my paper work plan. thanks.
jeff
11-14-2002 09:17:43
43560 square feet = 1 acre
209 ft by 209 feet =1 acre
Scott
11-14-2002 06:25:57
well, one rod = 16.5 sq. ft., and one acre is 160 sq. rod. So, 1 acre is 43,560 sq. ft, or 10 sq. chains.
Follow that? :)
Dick2
11-15-2002 03:06:15
 Re: Re: an acre yds? in reply to Scott, 11-14-2002 06:25:57
All of our fields in ND were 1/2 mile long, so a 16.5' cut was one acre. I used to do mental math with the width of whatever implement I was pulling to figure work rates, when I would finish the field, if I had enough seed, fertilizer, fuel, etc. Plows were 42" cut, field cultivator was 11.5', disc was 11', drill was 14', swather was 12', drag was 32', etc. Kept my mind from getting bored to do the mental math problems.
John Garner
11-14-2002 12:46:35
Scott --
We need a minor correction here . . . a rod is 16 1/2 feet (or 1/4 Gunther's chain), and an acre is 160 square chains (or 10 square Gunther's chains).
The "rod" is a linear unit, not an area unit, and a "chain" could be either a Gunther's or Surveyor's chain of 66 feet or an Engineer's chain of 100 feet.
John
GK
11-15-2002 20:20:24
 Re: Re: Re: an acre yds? in reply to John Garner, 11-14-2002 12:46:35
Sure will be nice when we finally dump this ancient system and go to the Metric System. Lot easier multiplying and dividing by 10.
jim
11-14-2002 06:17:05
If you get the chance , pick up an old John Deere Pocket Ledger. They were given out several years ago by JD dealers and contain a wealth of information on any measurement you can think of along with other info. They are now collectable but are worth every penny. The info you have been given by others is correct.
Steve
11-13-2002 23:14:25
Steve,
One acre that is square is 208 X 208'.
Mr.T.
Ray,IN
11-13-2002 20:33:21
All the answers are here for these problems.
Rusty 2N
11-17-2002 08:16:44
 Re: Re: an acre yds? in reply to Ray,IN, 11-13-2002 20:33:21
Thank you!!! that was worth saving.
hay
11-13-2002 16:37:44
43,560 sq ft = 1 acre
paul
11-13-2002 17:28:48
 Re: Re: an acre yds? in reply to hay, 11-13-2002 16:37:44
Yup. Can't remember my SS number, but have that one memorized. :)
--->Paul
JRN
11-14-2002 06:35:42
 Re: Re: Re: an acre yds? in reply to paul, 11-13-2002 17:28:48
The way I remember 43,560 is 7-11.
7=4+3 (43,000)
11=5+6 (560)
Rubintropfen
11-15-2002 19:22:10
 Re: Re: Re: Re: an acre yds? in reply to JRN, 11-14-2002 06:35:42
Hmm. The way I "remember" 43560 is that a square mile contains 640 acres (remember the Homestead Act?). (5280*5280)/640 = 43560.
