Help with Lincoln portable AC welder
Mike Speece
11-12-2002 17:08:59
I have an older 150 amp Ac stick welder powered by an 11 HP Briggs&Stratton. I need help/information about adjusting the govenor. I got it set so the power plant is producing correct voltage but the motor does not recover rpm when i strike an arc, thus the voltage drops and holding a bead is impossible. Anyone have experience with this? or the manual for a similar machine?
Thanks,
Mike
Drill
11-14-2002 07:02:08
 Re: help with Lincoln portable AC welder in reply to Mike Speece, 11-12-2002 17:08:59
I have heard od this problem before with these welders, the motor does not have enough power to pickup speed quickly after stricking arc. One person added another heavy flywheel between the motor and welder, claimed it held the speed better. Just something you might try.
Mike W
11-12-2002 19:32:47
Go to Precise Engine Repair. The guys on the forum there will be able to help you.
Mike W
11-12-2002 19:35:18
 Re: Re: help with Lincoln portable AC welder in reply to Mike W, 11-12-2002 19:32:47
Link is perr.com
T_Bone
11-12-2002 20:48:53
 Re: Re: Re: help with Lincoln portable AC welder in reply to Mike W, 11-12-2002 19:35:18
Hi Mike,
Heres the Lincoln website. Look under orperators manuals and they have the complete manual in PDF file. I would download it if they have what you want as they delete files from time to time.
T_Bone
