Rotozip
Update
ShepFL
11-11-2002 11:42:41
Really like the tool and cuts most materials with ease. I would say though that my inexperience and the high bit speed I have destroyed a few bits while cutting hardy board. If cutting this material do some practice and plan on spending a few extra bucks on bits.
FWIW
ajco
11-14-2002 17:54:48
 Re: Rotozip - Update in reply to ShepFL, 11-11-2002 11:42:41
A drywall screw cuts drywall&some other materials -cheap.
Huh?....Scott
11-14-2002 22:15:54
 Re: Re: Rotozip - Update in reply to ajco, 11-14-2002 17:54:48
A drywall screw?
How do you chuck it in, Grind off the head? How do you adjust for the wobble @ 20,000RPM?
I relly am interested, I'm just not sure how you get it to work.
Scott
smoknbs
11-11-2002 18:41:04
if hardy board ,Duroc, ceramics ,etc. spend the $ and get the Carbide bit in 1/4 inch .use them at work on duroc and never a problem.
dig
11-11-2002 15:26:28
I've heard that those things go through bits like crazy if you cut anything at all hard. Even some of the harder woods will destroy the bits.
Tommy
11-11-2002 16:18:34
 Re: Re: Rotozip - Update in reply to dig, 11-11-2002 15:26:28
I think the rotozip tools come with 1/8" and 1/4" collets and only 1/8" diameter cutting tools. Try to find some 1/4" diameter cutting tools and I believe some of the tool breakage will go away.
fredo
11-11-2002 20:56:34
 Re: Re: Re: Rotozip - Update in reply to Tommy, 11-11-2002 16:18:34
don't try to cut the piece in one pass,. make several passes if nessary
fredo
