High pressure sodium yard light.
Steven M
11-03-2002 17:12:00
My yard light goes on and off all night.
I'm sure it got hit by lightning. Can a light like this be repaired? If it can be repaired, where can i get parts to fix it. Maybe i'll just get a new one like i did last time, but if i could fix it for less money then a new one, it would be nice.
Farmered
11-19-2002 17:51:11
 Re: High pressure sodium yard light. in reply to Steven M, 11-03-2002 17:12:00
I once installed a new light on the South side of a white building. After some experimenting I found that the eye which I installed to the north, as I read in the directions, was picking up reflected light from the wall of the building.
After I turned the eye to the East I had no more problem.
Farmer Tom
11-04-2002 05:49:44
Sounds like the HPS bulb needs to be replaced. What you described is typical of a bad lamp or a lamp with a lotta hours on it. I'd try a lamp first and if it still acts the same try the photo-cell as mentioned before.
Raymond Bagwell
11-04-2002 10:09:12
 Re: Re: High pressure sodium yard light. in reply to Farmer Tom, 11-04-2002 05:49:44
If it is one of the cheaper lights you buy at one of the chain building and supply stores. It would probably be cheaper in the long run just to replace it. One trip to the store to buy a new light. Not one for a bulb then one for a photocell and then you could have a bad ballast. If it is cutting off and on because of light hitting the photo cell something had to change to cause this.
ger
11-04-2002 18:05:27
 Re: Re: Re: High pressure sodium yard light. in reply to Raymond Bagwell, 11-04-2002 10:09:12
i did that, raymond and the new one i put up did the same thing every time the washing machine would kick in at night the light would go out, when i was taking the old one down i noticed the bulb was barley hanging onto the sockit wonder it ever came on at all , so i ordered a new bulb for this new lite today an i,ll see if that makes a difference , i,ll let you all know in a day or to when my electrical supplies come the bulb is bein shipped with the rest of my order. i checked this bulb today before ordering a new one an something in it is rattling , so hopefully thats all it is, later ger
Short Round
11-04-2002 06:02:30
Farmer Tom is right, when a hps lamp nears the end of its life it starts to draw more current and the overload kicks out. When it cools down it will restrike and light again, so it is time to replace the lamp and your problem will be solved.
Charles(Mo)
11-04-2002 04:49:51
My light started going off anytime my heatpump kicked on. Just a little drain on the power was enough. I replaced the bulb and photo cell and that cleared that problem. The light is about 7 years old and that was the only problem. I don't think it was ever hit by lightning though.
hth
Charles
Gene Davis
11-03-2002 20:19:30
Sounds like you are having photo cell trouble. Is it seeing it's own reflected light and turning it's self off? Try covering the photo cell to see if it stays on, if so it may be turning it's self off.
Leon in Mn.
11-04-2002 18:13:00
 Re: Re: High pressure sodium yard light. in reply to Gene Davis, 11-03-2002 20:19:30
Farmer Tom is right. It is the bulb. I had this happen 2 times already. When the bulbs go bad or weak, they will go on and off especially when an appliance kicks in that will put a "bump" on the line drawing a slight voltage drop. I was told this by an experienced electrician of many years. It worked for me. Go with the bulb, I would bet on it.
ger
11-04-2002 18:43:15
 Re: Re: Re: High pressure sodium yard light. in reply to Leon in Mn., 11-04-2002 18:13:00
my old light worked great for years , then all a sudden if we were washing clothes at night i would notice that when the washer kicked in the light would go of , come back on a in little bit, i ordered a new light , was putting it up a bout a year ago when i took the old one down the bulb was just hanging wonder it worked at all, anyway i put up the new light it started doin the same thing , figured i had an electrical problem with the house ( it s new) any way after readin your posts this a.m. i got the ladder went up an took the bulb out , something rattling in it , so i ordered a new one should be hear tomorrow , i hope thats all it is as i all of a sudden , don,t like heights anymore lol, easier to change the bulb than the whole light fixture , guess we,ll see . later ger
tom shonkTOM SHONK
01-15-2004 15:48:07
 Re: Re: Re: Re: High pressure sodium yard light. in reply to ger, 11-04-2002 18:43:15
NEW LIGHT BULB NEW LIGHT SENSOR. WHAT ELSE COULD IT BE.
