Tempering steel
REDNECKMATT
11-01-2002 20:30:11
I want to know if there is anyway I can harden a peice of steel in my shop. I want to put a new starter bit on my post hole auger, I bought this big long bit at a sale but it looks like it was in a fire and wanted to know if there is a way I can make it hard again?
kraig WY
11-01-2002 22:26:58
 Re: tempering steel in reply to REDNECKMATT, 11-01-2002 20:30:11
You need to know the hardness you want then its a simple matter to temper steel. You can do it fancy by haveing a bunch of expensive equipment our you can do it with equipment you have on hand.
First you heat the metal to critical tempeture. You reach the critical when a magnet will no longer stick to the metal. Quench the metal in oil. Now you have to draw the temper. Which means, depending on the hardness desired, heat the metal in an oven for x amount of time at x amout of degrees. It the desired tempeture is right you can do it in a kitchen oven. Or in a lead pot (with a lead themother) (spelling). I've been doing this for years, making gun parts. I've never needed anything but a kitchen oven or lead pot (which I use for casting bullets). If you will e-mail me the hardness desired I will let you know what temp and for how long to draw the temper.
T_Bone
11-02-2002 18:21:32
 Re: Re: tempering steel in reply to kraig WY, 11-01-2002 22:26:58
Hi Matt,
You can also add surface hardening buy heating the part to cherry red then rubbing the part in powdered charcoal, cool to it's straw point (looks just like the color of wheat straw) then quench in oil. Heat again to about 500F then cool slowly adding the temper.
T_Bone
