Plasma cutter
Gary
10-29-2002 09:52:55
Is a hypertherm cutter the best buy? Can you get as intricate cut with a bigger torch over a smaller one?
Trae Clanton
12-22-2002 23:30:02
 Re: plasma cutter in reply to Gary, 10-29-2002 09:52:55
If I were you and if you haven't purchased a plasma cutter yet I would look very close at what consumables cost for the hypertherm. I looked at all of them and found the Thermal Dynamics to be the best of the best. I bought the Thermal Dynamics Cutmaster 38. It cuts up to 5/8 pretty easy. Also the cost of consumables is far cheaper than that of hypertherm. Also the torch is easier to use, lower cost getting into it and makes excellent cutts. Check into it Thermal Dynamics.
Dr.Evil
11-02-2002 06:19:59
I just bought a Hypertherm 600 (40A) machine about 2 months ago. Great little unit for what I use it for... mostly thinner gauge material. Works on steel up to 1/2, 5/8 & 3/4" with slower travel speeds. Best to use a straight edge when cutting or make a template of what You want to cut out. Have to have a steady hand.... but Mine saved Me several hours of edge prep. time on the first job I used it on. I was cutting sheets 2 or 3 feet square of 14 Ga. sheet. Cut it with the plasma torch.... hit it a couple passes with an abrasive flap wheel in a 4-1/2" angle grinder and You have an edge ready to weld. My local welding distributor said the Hypertherm is the easiest to get consumable parts for and is the most trouble-free unit so that's all they sell. They also sell Lincoln & Miller welders but only carry Hypertherm plasma cutters.
DumOleBob
10-29-2002 19:22:06
I have a Hypertherm 900 & like it a lot. Also they have very good factory support should you have any questions or problems. I cut on a CNC (computer controlled) table. The width of the kerf, and thus the degree of detail achieved, fine detail, depends mostly on the orifice size. Some plasma cutters offer two or more tips, which operate at different amps. I got mine at a very good price through an internet connection. If you want I'll send you their name. You may be just as well of going to a local dealer & talking about what you'll use it for.
dab
10-29-2002 10:48:15
Yes, you can do as much detail large as small. Miller is the best of the ones I've used.
