Hi Mark, Dave is right on. All metal has a film(oxides) on it that must be removed before welding. If your ever having a problem , it don't matter what metal your welding, clean it first and a SS wire brush is generally the best for cleaning. Even SS has a oxide that "should" be removed before welding. Ever wonder why some guys Tig welding looks so nice and smooth? 10 to 1 they prep'd the base metal down to white metal with a wire brush. The SS wire brush starts to grab when you hit "white" metal. While Tig welding and other weld processes, I like using Tig as examples as Tig allows the orperator to "see" what makes a good weld puddle as the orperator has better control of the weld puddle than other methods. With the base metal clean the weld puddle fills out to the same width every time, with the base metal dirty(contaminated) the weld puddle will flow smooth then shrink in then go wide again and this is the weld puddle trying to adhere to a dirty surface thus changing the heat required to pentrate the base metal thus creating a uneven weld bead. 4330 is probabbly the best all around AL filler wire. I'm still leaning towards a ground problem. You could also have a dirty liner or a liner that doesn't make good contact at the liner clamp. With AL you usually have a build up of wire skin right at where the wire enters the liner that also can cause the problem. Take some time and tare the gun down from the feed rolls out. Clean everything very well with alcohol. Don't forget to add a foam ear plug on the wire as it enters the liner as this helps keeps the wire clean. e-mail me if you still have problems then we'll post the final results for everyone to read. T_Bone
