Dividing head
Johnny Smith
04-11-2000 17:16:33
I have a dividing head that I purchased with some other eqipement. Can anyone tell me how to setup and use? It came with three plates, I know what it is supposed to do but cannot figure it out.
Johnny Smith
04-14-2000 15:46:29
 Re: dividing head in reply to Johnny Smith, 04-11-2000 17:16:33
Thanks to Roger for the explanation on the setup of a dividing head. I build miniature wagons, Stagecoaches and such and had planned to use the dividing head to drill the holes for the spokes in the wheels and hubs. I never build them the same size and like to make each different. It was a breaze to figure out the math and punch out the parts. Thanks again. Johnny
Fred
04-14-2000 08:58:28
Your advice looks good to me. There are easy and hard ways for using a dividing head, plain or rapid easy, compound or differential or angular require your head and a lot of algebra. If yours has a lever to disengage the worm gear and make it free wheeling and a plate on the back or front with a common number of holes like 24, that is the easiest way, but, your divisions must be divisible by 24. Guys didn't tell you to lock the spindle before every cut so their parts are scrap (LOL) Seriously, you guys did a good job. And a year from now he'll tell us how to setup a gear train on a universal horizontal mill to cut a helical gear for a Chevy transmission. Or to gash a worm. I'll pay particular attention when he explains roll over when cutting a bevel gear. I used to teach gear cutting in the navy and I know it's frustrating to some. In fact, I saw a fellow drag a big dividing head over to a shell port and deep sixed it just so he wouldn't have to cut gears the next day. I could have hung him but I didn't even tell him that I was watching. I wonder if he's reading this reply? Hmmm Hi Ron in Illinois...(If you are).
Dave in Mo
04-12-2000 09:18:12
Johnny, I'd go and pick up a used copy of Machinery's Handbook or equiv at a book sale. It would have that info plus a bunch more...you don't need the latest edition. I think mine is from 1955.
Roger Prosper
04-11-2000 20:31:28
Hi:
A dividing head is used for accurately rotating workpieces on a milling machine when making repetitive, evenly spaced (usually) cuts, like gear teeth or flats on a nut. It is usually mounted in the t slots of the bed of a milling machine. The workpiece is often mounted on a mandrel which is supported at one end by a chuck or center (in the indexing head), and the other by a footrest, like a center in a tailstock of a lathe. Head and footstock must be accurately in line or the accuracy of your work will be non existent.
The numbered,holed,plates are used to accurately keep track of the turning of the handle on the indexing head. The handle is usually at a 40:1 gear ratio to the chuck that holds the mandrel or workpiece under the milling machine cutter. Therefore, if you make one turn of the handle (clockwise), the workpiece will rotate 1/40 or a turn. You can accurately cut 40 sides on your workpiece by doing this. But, you say, I want to cut 10 sides, not 40 sides. In that case, turn the handle 4 times. 40/10 =4. 8 sides, 5 turns, 40/8=5.See how it works? You can usually come up with any number of sides you need with the formula: Required turns of handle = 40/n, where n = number of evenly spaced cuts you wish to make.
This only works if you have a 40:1 ratio. Wide range dividing heads usually have a finer 80:1 ratio or more, which gives them more possible indexing combinations. Mark your indexing head and turn the handle until the mark rotates around fully to the position in which it started, The number of turns required to make one complete revolution will tell you your gear ratio. Put the resulting number in the above formula instead of 40.
Say you want to make a six sided nut.
For a 40: 1 dividing head:
Turns=40/n = 40 /6 = 6.66666 66....or 6 and 2/3 turns.
Whoa, you say, how do I make 2/3 of a turn then?
Easy. If you do the reverse of reducing a fraction to lowest terms, you will eventually come up with a fraction that has a denominator that is the same as the number of holes in one of the circles on one of your plates.
Say, for arguments sake, that the largest number of concentric holes on your plate is 18. ( I know it probably is much higher than that but bear with me.)
2/3 will equal what out of 18? 12.
12/18 is the same as 2/3. As I said, it's basically like doing the opposite of reducing a fraction to lowest terms.
So, if you set the pin in the handle to run in the circle with 18 holes in it,and you turn your handle 6 full turns, plus 12 out of 18 holes, you will have turned the workpiece 1/6 of a complete turn under the milling machine cutter. If you put the pin in the circle with 36 holes, it will be 6 full turns + 24 out of 36 holes. Or 6 full turns + 36 out of 54 holes. They will all turn the workpiece 1/6 of a turn. I was taught to always use the circle with the largest # of applicable holes (54 in this case). I don't know why. Instilling a work ethic perhaps. Usually, the indexing head will also have two little sector arms under the handle, just over the plate. Space them apart the correct distance so you don't have to count holes every time. Just turn your handle the correct number of full turns, then forward till it reaches the arm spaced the correct number of holes forward (i.e. 12/18 holes for the above example).Do NOT include the hole that the pin is currently in when setting the spacing of the sector arms. Then after you put the pin in the hole in the plate, rotate the arms forward (clockwise)to indicate the hole the pin should end up in after the correct number of turns have been completed. Always push the arm farthest from the pin clockwise toward the pin. If you push the arm closest to the pin, the distance between the sector arms may decrease and lead to indexing errors as you progress through the job. This may be hard to visualize I know, and your head may be constructed differently than the ones I have used, but that is what a dividing (indexing) head does. It allows you to accurately rotate a workpiece on a milling machine to position it for a cut. I am sure there are many others out there who can explain in more depth the intricacies of indexing. The real fun begins when you come up with a fraction that doesn't correlate to any of the numbered circles, or you want to cut a spiral flute or a helical or hypoid gear!
Experiment a bit. You will soon get the hang of it.
john d
04-12-2000 09:13:30
 Re: Re: dividing head in reply to Roger Prosper, 04-11-2000 20:31:28
EXCELLENT!!
Neal
04-12-2000 06:21:24
Bravo!! You explained it very well! I really don't have anything to add except I have also used it in a surface grinder and turned verticaly in the mill to engrave reference marks. Neal
Terry (NC)
04-11-2000 21:49:30
Couldn't have said it better, just wanted to add a couple of things. The dividing head can also be used on a lathe. I used to have a versa-mill which is basically a milling attatchment that mounted on the lathe carriage. Same principle.
Also, it is important to remember that if you ever accidently pass your hole on the plate you shouldn't just turn it backwards. It is tempting when you are just past it, but don't do it. It will throw your project off. You'll find this when you make your last pass. If you miss your hole then remember, 40 turns will get you right back to it or if you must go back, go way past the hole then come back on it to get the backlash back out of it.
Bill
04-12-2000 15:55:21
 Re: Re: Re: dividing head in reply to Terry (NC), 04-11-2000 21:49:30
Great explanation ysing a dividing head is almost a lost art. Another suggestio get a machinist text book there are a lot them surplus now that nc has taken over
John
04-12-2000 18:43:15
 Re: Re: Re: Re: dividing head in reply to Bill, 04-12-2000 15:55:21
Bill;
The gear hob was what made using the dividing head a dying art.
