Epoxy Floor Paint
F14
10-26-2002 14:17:27
There was a discussion a week or so ago about painting cement floors. Can't remember which board it was on (CRS, ya know).
Anyhoo, I said I'd check to see what paint we used at the firehouse, that we've had very good wear from.
Da Chief sez it was a two-part mix from (of all places) Sherwin-Williams!
Hope whoever wanted the information finds it here...
WkEnd Frmr
10-30-2002 09:44:56
 Re: Epoxy Floor Paint in reply to F14, 10-26-2002 14:17:27
Just finished acid etching our floor..no big deal..1 gal. muriatic acid to 5 gal. water..use a good quality mop and wet the floor pretty good..it removes the cement dust..in a pinch,could be skipped..Sher.Wllms. paint..B65 ab45 (texaco gray)/B65 4500-hrdner /#132 reducer
I put the first coat on a little thin and top coat w/no thinning . good luck p.s. when done the mop is pretty much toast
Rod MI
10-27-2002 15:57:24
Thanks F14 I kind of thought it would be Sherwin-Williams that must be what we use at work. We have a account with them but I didn�t now for shire and no one knows at work the brand we use thanks Rod MI
Chuck, WA
10-27-2002 06:59:47
Thanks! There may have been others, but I had asked back a month or more ago. The barn just finished yesterday - closed, but still trim left to install - and the floor has cured a minimum of about a month now - poured in three slabs over a couple of months. Some of the labels I've read call for a 90 day cure, then acid etch. Not sure I want to go that far - the etch that is - but could hold for the 90 day cure on the newest slab.
This won't be a heavy wear situation, so maximum toughness isn't a problem, and we put down plastic under the concrete over pretty dry clay, so moisture shouldn't be a problem either. Guess I'm still chewing on the acid etch issue since I still have time waiting out the cure. Sounds like a spring job since temperatures may not be right till then.
Thanks for the followup! I'll look into Sherwin-Williams epoxy.
F14 - That long, eh?
10-27-2002 10:03:29
 Re: Re: Epoxy Floor Paint in reply to Chuck, WA, 10-27-2002 06:59:47
Well, ya know what they say, "Time flys like an arrow. Fruit flies like a banana"...
Glad I could help. Don't think we etched our floors, but I could double check that.
larry
10-26-2002 16:02:26
I was interested in the epoxy floor paint, but i get moisture thru my floor so i dont guess i should put anything on the floor. Thanks for the info though.
