Air compressor sprayer
Ed
10-25-2002 18:02:09
Does any know if they make a tank (say around 5 gal.) connectable to air compressor that has means of filling it with liquid to be used as sprayer??
buck
10-26-2002 15:44:12
 Re: air compressor sprayer in reply to Ed, 10-25-2002 18:02:09
Have you considered an old fire extinguisher--the kind that used water with compressed air.
Ed
10-26-2002 05:08:33
OK guys--here's the deal. A roof sprayer where compressor and tank sit on the ground with long hose up to man spraying bleach on roof. (To remove mildew). Surely there is a setup similar to that for people who do that kind of work.
JoeK
10-26-2002 00:43:22
Dunno what you want to spray,but if it does not have to be completely portable(could stay connected to compressor.I use a cheapo$10-12 siphon sprayer hooked to air and pulling degreaser,roundup mix etc from a 5gal plastic
pail.No reason same setup couldn't be used with a portable air tank or a small portable gas compressor.Northern has sprayer wand as"engine cleaning gun"15545-C146,listed with their air tool accessories.
JoeK
10-26-2002 00:43:20
Kelvin
10-25-2002 18:07:12
Just a thought: I've got about a 5 gal sandblast tank from Northern Hydraulics. Has about a 2-1/2" cap on the top where you put the sand in. Looks like it could be used to spray-with the right outlet hose-as well as sandblast.
Ed
10-25-2002 18:57:05
 Re: Re: air compressor sprayer in reply to Kelvin, 10-25-2002 18:07:12
Thanks for the tip Kelvin. I also see Northern has a poly tank that would be great--BUT it is a 30 gal. at 80 bucks.
