Part for rotary tiller
S. Gill
04-11-2000 13:01:35
I am new to this, so not sure if I am doing it correctly.
I am am investigating for my father-in-law the possibility of getting a part/parts for his rotary tiller which was made by Gilson Brothers. I have this information and wonder if anyone could help me as far as where to go from here.
He has a rotary tiller, model #Gil-1580E and needs part #18825 (possibly i8825, but I think it is a "1" (seals & felts).
Thanks to anyone who might give me some feedback, pos or neg.
Jack Craton
03-10-2001 05:39:55
 Re: Part for rotary tiller in reply to S. Gill, 04-11-2000 13:01:35
need parts for Gilson tine tiller
Model num. 51134
part num.33632 Idler pulley assembly
esmaeil
12-23-2005 21:00:39
 Re: Re: Part for rotary tiller in reply to Jack Craton, 03-10-2001 05:39:55
Please
Rick
04-11-2000 17:52:35
If it is a seal that you are looking for take the number on the outside of the seal, or better yet the seal itself to an industrial bearings and/or seal distributor. They can probabaly match it and it will probably be less expensive than a dealers part. We have found seals and bearings from the supplier below. They have a lot of branches around.
Good Luck
Paul Fox
04-11-2000 15:12:01
Two ideas:
1. Do a web search with your favorite search engine for Gilson (or Gilson Tillers). That might hit either some dealers or a web site dedicated to their equipment. I know their lawn tractors are quite popular here in the Northeast.
2. Take that seal number to your local NAPA store, and the seal if you can. There's a good chance they can cross it to a NAPA part.
Doug Wilkerson
03-15-2001 04:23:49
 Re: Re: Part for rotary tiller in reply to Paul Fox, 04-11-2000 15:12:01
Looking for manual for Gilson Reartine Tiller model # 51134G 46925 - serial # 1300C1-800 or any info for the above - thanks.
Jerry W. Hurley
05-12-2003 09:20:53
 Re: Re: Re: Part for rotary tiller in reply to Doug Wilkerson, 03-15-2001 04:23:49
Looking for service manual for rear tine tiller #51134-45917.
Christopher March
05-05-2002 07:20:49
I am searching for a part that go on a Roper transmission on a sears model no 917.299.130 part no 102116x Sprocket assembly(tine)
Doug Wilkerson
03-15-2001 04:23:30
Dave Lambert
05-11-2001 19:52:01
 Re: Re: Re: Part for rotary tiller in reply to Doug Wilkerson, 03-15-2001 04:23:30
I have a manual for a front tine tiller model number 857-41802. I have two of these tillers and need a lower gear for one of the units. It is a brass gear with the letter D stamped on it but has no number that I can see. If anyone can help I would be most appreciative...
