Does my garage door opener motor need a capacitor ???
Alberta Mike
10-22-2002 07:49:29
My garage door opener electric motor is giving me problems. I have determined that it doesn't have any "start-up" power. The wall button and remote are signalling the unit to start but it won't. I can prevent the motor from starting by putting even the smallest bit of hand pressure on the pulley (no belt attatched). If I signal it to start then give the belt a little push, the motor starts up and works fine, seems to have lots of power once it's spinning. A friend of mine said it is probably a capacitor start motor (the motor has no brushes, etc.). Is the capacitor the cylindrical shaped part with two wires going in from the control unit and two wires going out to the motor? Any help on this would be appreciated.
teadave
10-23-2002 19:38:39
 Re: Does my garage door opener motor need a capacitor ??? in reply to Alberta Mike, 10-22-2002 07:49:29
finally one i can help with. i service these things for a living,and you may well have figured it out. post the brand and model# and i will give you all the help i can.
teadave
Alberta Mike
10-23-2002 21:17:47
 Re: Re: Does my garage door opener motor need a capacitor ??? in reply to teadave, 10-23-2002 19:38:39
Bought a new capacitor and everything is working find now. Thanks to everyone for their help.
Bill
10-22-2002 19:37:42
how I check the capacitor is to apply power and shut it off. Then bridge the 2 wires going to the motor with an insulated handle screwdriver. You should get a strong arc, but be sure to be holding the insulated handle as it's going to be a strong Zap. This is the charge to start the motor under load. No zap means the capacitor is leaking or shorted. Hope this helps, but be careful- you don't want to get the shock off it.
Herkimer Neely, Sask.
10-22-2002 12:19:56
I don't know anything about garage door openers but when mine acts up I check air pressure in my tractor's tires and the specific gravity of the engine coolant. Hope this helps
Alberta Mike
10-22-2002 13:02:28
 Re: Re: Does my garage door opener motor need a capacitor ??? in reply to Herkimer Neely, Sask., 10-22-2002 12:19:56
I noticed that you just said Saskatchewan but didn't mention the town. That's because you know that I might do a little dropping tire pressure myself if I knew where you lived. I didn't think you could drop tire pressure on the ETD's since they were factory sealed (like Rolls Royces).
10-23-2002 09:26:15
 Re: Re: Re: Does my garage door opener motor need a capacitor ??? in reply to Alberta Mike, 10-22-2002 13:02:28
Yup Mike, that's true. They are sealed at the factory, But I thought you had the Hydroincliner meter to service them. BTW, I live in Sask, Utah and have restored a Merriweather Hauls-All.
Sidney from RMH
10-22-2002 19:09:29
Ahem....you guys are gonna get yer pp's whapped..... .
TimC
10-22-2002 12:02:18
Typically it is mounted to the motor. Long round black plastic thing with a metal cover over it.
Check the connections on the cap first. Sometimes they get loose or warm and then stop making a good connection. They are cheap to replace.
RayP(MI)
10-22-2002 17:17:43
 Re: Re: Does my garage door opener motor need a capacitor ??? in reply to TimC, 10-22-2002 12:02:18
If there is a capacitor to be replaced, be sure to replace with one of similar ratings. The ratings will be printed on the capacitor.
