Sheet metal brake
Tom
10-21-2002 10:15:21
I have the opportunity to buy a 48" sheet metal brake that has a 20 gauge sheetmetal capacity. My question is: Is the 20 gauge the capacity for when you are bending a full 48 inch wide piece, or can you bend a 16 gauge piece that is 12 inches wide without running into some sort of problem? I know to some of you this may sound like a dumb question, but any help would be appreciated.
Tom
10-22-2002 05:09:18
 Re: sheet metal brake in reply to Tom , 10-21-2002 10:15:21
Thanks everyone for the replies. I always get the answers I need from here. (Sometimes not the answers I want hear.)
Dusty MI.
10-21-2002 16:58:19
I have an 8' brake rated to bend up to 18ga. It does n't do a good of bending an 8' sheet of 18ga. but if I set the nose leaf back, I turn the adjusting screws back 1 1/2 turns, it will do a nice job of bending 16ga. up to 3 feet. There are times that I wish I had a box brake. Dusty
Dan
10-21-2002 14:32:30
Tom
Your thinking is right, IF the clamping leaf is adjustable. You need to be able to move the clamping leaf backward so that there is enough space between the nose of the clamping leaf and the edge of the bending leaf when you bend a peice of 16 ga. material to 90 degrees or past. If the clamping leaf has a fixed position for 20 ga. and you try to bend 16ga. when you get to the point were the bend is close to 90 degrees there isn t going to be enough clearance between the parts of the brake to allow for the difference in material thickness and either the bending leaf or clamping leaf is going to flex. If the machine has adjustability for varies thicknesses I would think that the owners manual would give you its maximum capability at different thicknesses.
I hope you can make some sense out of this.
T_Bone
10-21-2002 16:12:13
 Re: Re: sheet metal brake in reply to Dan, 10-21-2002 14:32:30
Hi Tom,
If your considering a 4ft solid leaf brake there not as handy as they sound. Now a 20ga box brake (one that has a sloted nose bar) you can use to make alot of different projects. A new Tensmith 4ft box brake is probably around $600 new. Not the best for a commerical shop but is nice for a home shop.
To check a used brake before buying:
Look at the pivot points of the clamping nose bar for ware.
Flip up the bending leaf 90 and observe the gap between the leaf and the bed. This gap should be equal all the way accross. If not then look for ware. Not too much ware then it can be adjusted.
Take a scrape piece of 20ga black iron and bend a 90. If the ends of the 90 are under/over broke then the nose bar is warped. Most nose bars can be adjusted with the center nut a small amount.
T_Bone
