Northern Hydraulic waste-oil heaters
Eric Perry
10-13-2002 19:24:30
I am looking into heating my fathers work shop. I am planing on running some hot-water baseboard we removed from a house that was being torn down and feeding it from a furnace in my shop which is an addition to his building. I would also like to use a waste-oil heater to be able to get rid of the oil we get from oil changes. Has anyone tried one of the units that Northern Hydraulic sells? I was wondering how reliable they are and if they run quiet. Thanks for any information anyone can send, Eric Perry.
bruce
10-14-2002 04:13:43
 Re: Northern Hydraulic waste-oil heaters in reply to Eric Perry, 10-13-2002 19:24:30
Hi i work at a place that makes waste oil furances only for shops they work fine depends on the burner they will use a lot of oil so have a lot on hand if you use this much they work good.m here is the site www.siebring.com
Terry in IN
10-25-2002 20:59:05
 Re: Re: Northern Hydraulic waste-oil heaters in reply to bruce, 10-14-2002 04:13:43
A couple years ago I installed an Econo-Burn waste oil heater. It is 180,000btu. It burns about 1.3 gal of oil an hour. I am pleased with it. It has been reliable. It needs cleaned out about every 600-700 hours. Econo-Burn has been around a while. I almost got burned by a company in the northwest, but don't recall who it was now. Ask the manufacturer for some references of users in your area.
Eric Perry
10-19-2002 19:29:04
Bruce, Thanks for the reply. I'll look into the 150000 BTU unit. That is the same size as the one in the Northern Hydraulic catalog.
Thanks for the info, Eric.
Richard
10-15-2002 03:03:20
Are you sure that is the right address? Maybe I missed it but I never saw anything related to a heater.
Bruce wrong address siebringmfg.com
10-16-2002 18:22:18
 Re: Re: Re: Northern Hydraulic waste-oil heaters in reply to Richard, 10-15-2002 03:03:20
Hi
sorry i have the wrong site address its
www.siebringmfg.com
