Superbooster!
Paul
10-11-2002 18:24:37
I have one of those portable 12 volt battery booster packs that works great. The problem is, I have some 6 volt tractors that need a boost sometimes. How can I use this 12 volt booster on a 6 volt system? I don't want to burn up the generator,coil,battery, or anything else.
Thanks in advance!
Fred OH
10-18-2002 10:00:09
 Re: Superbooster! in reply to Paul, 10-11-2002 18:24:37
Each cell in a battery contains about two volts. I have counted over to the third cell and drilled a hole in the top of a battery and screwed a screw into it and with that and the ground had six volts. I think I ran a six volt radio from this arrangement....but, it would make the batteries current at half mast. L8R....Fred OH
JDK
10-11-2002 22:21:43
We used to regularly boost 6V tractors w/12V vehicle.Do NOT hook to battery.After making sure tractor is in Neutral,PTO off,turn on key and connect to frame or block of tractor with one cable and touch other cable to main lug of starter,observing tractors polarity.
This will IMMEDIATELY activate starter BYPASSING ALL SAFETY SWITCHS/NEUTRAL SWITCHES so be EXTREMELY CAREFUL!!
Do not turn 6V starter for long periods on 12V.
RWK in WI
10-12-2002 18:19:02
 Re: Re: Superbooster! in reply to JDK, 10-11-2002 22:21:43
One suggestion - Connect the first jumper/booster cable to the starter post and then just touch the other jumper/booster cable to a frame ground. Takes the spark away from a sensitive area and you can even be sitting on the tractor for safety.
For what it is worth.
paul
10-12-2002 22:21:11
 Re: Re: Re: Superbooster! in reply to RWK in WI, 10-12-2002 18:19:02
That's the way to do it, but will the little booster pack have enough juice to turn the starter by itself? Really never used one, but I thought they were more of an 'assist' then the main power....
I don't think there is a way to mix the voltages to make it work as a true 'booster'.
--->Paul
Ludwig
10-13-2002 20:05:36
 Re: Re: Re: Re: Superbooster! in reply to paul, 10-12-2002 22:21:11
That little booster should sure spin any 6v tractor starter. We used one once on my wife's mercedes diesel car before it was ours. The battery wouldn't spin the starter at all, just "click". Put that little booster on for awhile and varrrooom!
