Question about welding 4130
Kerry Miller
10-11-2002 11:56:41
A friend is loaning me his little TIG welder to play with and I want to use it to weld some 4130 1/2" .058 wall tubing. I've never used one of these machines before, only used a stick welder or a torch.
What kind of wire do I need to use to weld 4130 steel? As I said, it's fairly small, 1/2" tubing with a wall thickness of .058.
Yes, I'll practice a lot before I have to do the real thing!
Thanks,
Kerry
Rod MI
10-11-2002 22:50:31
 Re: Question about welding 4130 in reply to Kerry Miller, 10-11-2002 11:56:41
I would use ER80S-D2 but check this link out it should answer most questions
Link
Link
Grate Welding Forum
http://groups.google.com/groups?hl=en&lr=&ie=UTF-8&oe=utf-8&group=sci.engr.joining.welding
Kerry
10-12-2002 05:16:45
 Re: Re: Question about welding 4130 in reply to Rod MI, 10-11-2002 22:50:31
Thanks, that should help, I'm about to go get the little welder this a.m.
