Log Splitter
DCM
10-03-2002 10:48:59
Help!
Have a old log splitter which I believe is a "Lickity Split". Replacing fluid and filter for the system. Can not find the filter for the machine. The old filter has no name or information on it. On the back of the filter can it says: to replace with an S-28 filter. No one has any clue what this is. Am looking for any information on this or the manufacturer or dealer for this log splitter. Any ideas would be greatly appreciated. Have lots of logs and winter is coming soon. Thank you
steve
11-10-2003 18:17:31
 Re: Log Splitter in reply to DCM, 10-03-2002 10:48:59
You need a "Spin On Filter" Part number 2011062. You can try calling Piqua Engineering Inc. at 513-773-2464.
Located in Piqua, Ohio
dolan
11-13-2003 23:10:18
 Re: Re: Log Splitter in reply to steve, 11-10-2003 18:17:31
maybe try WEBBS 831-475-1020
Dave
10-03-2002 12:23:18
take the old filter to a NAPA store...they can most times match it up.
Howard
02-19-2003 08:36:27
 Re: Re: Log Splitter in reply to Dave, 10-03-2002 12:23:18
How did you make out, I know this is late. The filter should only be a fine mesh screen that can be cleaned in some solvent or gas. The oil is 10w straight non detergent type. NOT HYD OIL!!! I have a manual for the single speed and two speed lickity splitters if you need more info. The manufacturer of these great machines has been gone for quite some time.
Jay
09-13-2003 06:34:10
 Re: Re: Re: Log Splitter in reply to Howard, 02-19-2003 08:36:27
I have a Lickity Splitter which I believe needs the return spring replaced or at least looked at. Any ideas on service centers for these great splitters in the southern NJ area?
